2.8 manual flywheel on 3.1 that had an auto tranny
Old Mar 6, 2009 | 03:12 PM
hydrolic144's Avatar
Car: 1987 GTA Trans Am
Axle/Gears: Borg Warner 9-Bolt 3.27
I've looked but im not quite sure. I've had some nasty vibrations and just a short while ago found out that I hadn't installed a pilot bearing on the 3.1. Okay. I did that. But I still had vibrations even after. Then a buddy of mine said maybe the flywheel isn't right. So. The flywheel I have on there now is from a 2.8. The 3.1 that I swapped in my car was originally an auto. Is this the wrong flywheel? Any help would be greatly appreciated.
Old Mar 6, 2009 | 09:16 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 2.8 manual flywheel on 3.1 that had an auto tranny
Nope. Got the wrong wheel, there. Only a couple of years of the 2.8 were internally balanced (if any), and all 3.1's were. Get the right wheel and see what happens (or just remove the one you got and crank up a grinder to grind the balance weight off of the crank side).
camaro11j
Sep 19, 2018 08:49 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
gta90
Sep 15, 2015 04:00 PM
Trickskier
Aug 29, 2015 01:12 PM
ambainb
Aug 29, 2015 12:43 AM
