3.1 heads?
Old Mar 10, 2009 | 08:32 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
3.1 heads?
any one have their heads done lately what did they cost? and what is the largest valves you can run? and is 290hp naturally aspirated possible. if so what will i need. ooo. and what is the highest a stock 700r4 can handle?
Old Mar 10, 2009 | 10:41 AM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: 3.1 heads?
Head porting varies by the shop. A local guy just doing it as a side project for people he knows would do mine for $300. Others on here have paid nearly a grand.
I've seen the valves mentioned on here, but it was a while ago. I'm sure someone will chime in with "search".
290hp is possible, but not for cheap. That will be a very high rpm engine, and I don't think the iron heads flow well enough to make it there. Aluminum heads, fwd intake, and aggressive cam should make around 300 hp.A healthy 700r4 should be able to take a 300 hp v6.
Old Mar 11, 2009 | 07:33 AM
wes2008's Avatar
Car: 1992 Rs camaro
Engine: 3.1l
Transmission: 700-4
Re: 3.1 heads?
thanks, im just thinkin about the route im going to do naturally aspirated or mild turbo.
Old Mar 12, 2009 | 06:36 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 3.1 heads?
just make sure that 700r4 is healthy, or youre gonna rip it apart. most guys who have put a good amount of hp to that trans, say goodnight fairly soon. while i have a manual, id say if you have about 100k on the clock or if youve been hard on it/no maintenence, get a reman or rebuild it.
Old Mar 12, 2009 | 09:44 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 3.1 heads?
300 hp has been done with iron heads before, but only with extensive porting, huge cam, lots of compression and a manifold that's not made any more. You'll spend alot more trying to get the iron heads to 300 hp than it's worth. Turbo it.
Old Mar 12, 2009 | 09:59 PM
project89's Avatar
Re: 3.1 heads?
u can only go slightly bigger on both the intake and ex valves due to the spacing of them.
not worth it except on a max effort engine
at minumum at 300 hp u will need a shift kit in the autotrans, and i would also suggest a servo kit
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
