2.8 stroker ???'s
Old Mar 23, 2009 | 01:06 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
2.8 stroker ???'s
first, I did a search but could not find anything, I'm looking to make a spare 2.8 a stroker motor, what 3.1 crankshaft and pistons will work, this is for a 85 camaro 2.8 motor.
Old Mar 23, 2009 | 01:27 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 2.8 stroker ???'s
Suprised you didn't find anything, this has been brought up many times. You need to look for a 3.1 crank without the reluctor wheel cast into the crank. I have no idea what years may have had them but I'd look at '90 3.1's and get the flexplate & harmonic balancer with it. Pistons from the same motor will work, but you can mill the 2.8 pistons to fit for a little more compression.
Old Mar 23, 2009 | 02:10 PM
elthomas's Avatar
Car: 1985 Camaro
Engine: 2.8l v6
Transmission: auto
I am assuming it needs to be a rwd, not fwd crank, plus i did find somethings, I was just wondering which particular vehicles it was in.
Old Mar 23, 2009 | 02:34 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
go to ebay and put in 2.8 stroker kit...there is a kit there thats pistons ,rods,bearings the works
Old Mar 24, 2009 | 11:55 AM
bl85c's Avatar
Car: '85 maro
You can find them in camaros/firebirds and fwd cars. Like I said I have no idea which specific cars had the non-dis cranks because only a limited number were made and used more or less randomly.
86maro_252
Oct 10, 2015 06:52 PM
Nervous2
Oct 8, 2015 10:53 PM
usafirebird
Sep 29, 2015 11:58 PM
JSDaddy189
Sep 26, 2015 03:50 PM
spartanreaper
Sep 25, 2015 07:22 PM
