Cams to lower compression?
Old Mar 27, 2009 | 12:36 PM
artemis's Avatar
Car: 1987 Camaro Z28
So I'm looking into turbo charging my 3.1, I was wondering if anyone made cams to lower my compression so I can increase boost. Any thoughts? Or maybe if there are any cast pistons I could install from another engine that would lower compression.
Old Mar 27, 2009 | 02:25 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Cams to lower compression?
Using a cam with a late intake closing point to lower the dynamic compression only works on na engines, boosted engines are obviously under pressure negating the effects of a large cam under boost. You can find other pistons, but why would you want to? Lowering the compression to squeeze a little more boost in is basically just a tradeoff without any gains. It'll be weaker when not in boost and won't make any more power than a higher c/r, lower boost combo.
Old Mar 27, 2009 | 02:31 PM
artemis's Avatar
So i'm better off getting an alky injection kit or something of that sort if I wanna raise boost?
Old Mar 27, 2009 | 03:50 PM
project89's Avatar
stock c/r? **** boost that thing to 14psi without methanol, and throw meth on it if u want to go any higher
Old Mar 27, 2009 | 04:40 PM
artemis's Avatar
It'll take 14 psi on pump gas and stock internals?
Old Mar 27, 2009 | 04:41 PM
project89's Avatar
it will take more then that if u can tune it right
Old Mar 27, 2009 | 08:28 PM
bl85c's Avatar
Car: '85 maro
That's more or less what project89 has done (with an intercooler). Stock rods are forged, stock crank is nodular iron and the stock pistons can hold up to almoast anything you throw at it short of detonation. Hypereutectic pistons are actually stronger than forged, but much more brittle.
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
355tpipickup
Aug 13, 2015 07:35 AM
