2.8 Starts then dies
Old May 3, 2009 | 04:47 PM
mongoosekeith's Avatar
I just picked this care up and had to replace the fuel pump. did that and we are now ready to start it up. The only thing is it will start and then die. it will do this as many times as the battery will let it. We used a paper clip to read the codes, one was 1 long flash and one short, the other was one long two short. The car is an 88 rs with the 2.8 any help would be appreciated.
Keith
Old May 3, 2009 | 06:28 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: 2.8 Starts then dies
Keith
their are no long flashes. it is 12.
x-xx-x-xx means it is in diagnostics mode, then reads you the code. im interested to find out the reason as there is a few camaros locally that are doing the same thing for cheap.
good luck.
Old May 3, 2009 | 06:43 PM
so far it has been the vac lines
Old May 3, 2009 | 07:14 PM
throttle position sensor and idle air control is outta wack. and vacuum lines are all jacked up. My Grandpa and i have been messing with this since i posted this.
Old May 4, 2009 | 06:44 AM
sloick's Avatar
Car: Many
Engine: Several
any luck? maybe its a fuel pressure issue.
Old May 4, 2009 | 11:16 AM
the tps is getting 5 volts on one plug and 50 millievolts so thats the problem i guess. It will run as long as you dont let it idel. At first it was running on 3 cylinders at first but we cleaned the spark plugs and it works now but still dies. But we have a friend that was a GM mechanic and has a reader for my car. I will let you know when i get this figured out.
Old May 4, 2009 | 10:21 PM
today we found out the gasket between the intake and block was messed up, also the TPS is screwed too. more to come when we have the reader hooked up again
Orr89RocZ
Apr 25, 2016 08:28 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Andrew6.688
Dec 13, 2015 10:59 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
EFR2000
Aug 18, 2015 08:54 PM
