89 RS throwing a fit HELP
Old May 6, 2009 | 04:58 PM
Lestrey08's Avatar
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
2.8 engine sometimes wont let me get pass 3000 rpm's and throttle response is nothing like it should be jerks back and forth , dies out sometimes and is suckin gas like i gotta v16 I need help
Old May 6, 2009 | 05:38 PM
bevincarva's Avatar
Re: 89 RS throwing a fit HELP
try checking out if your car is throwing codes https://www.thirdgen.org/service-eng...ht-error-codes its a good place to start with were the problem could be occuring
Old May 6, 2009 | 06:23 PM
Lestrey08's Avatar
Engine: 2.8 V6
oh yea the check light comes on but goes right back off then when i try 2 check codes with a jumper wire and no codes show up not even 12
Old May 6, 2009 | 06:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You do realize that the SES light flashes the codes (you have to wait until after the light goes off when you turn the key on for the codes), and that they aren't displayed on the radio or anything (like some older Caddys and the like), don't you? If you weren't even getting code 12, I seriously doubt the engine would run in the first place (symptom of a fried ECM or other ECM problem, to start with).
Either way, I would start with a tune up (sounds like this hasn't been done in a while), and I would definitely take the ignition module inside the distributor to AutoZone or somewhere and have it tested. Also check to see if any plug wires have melted to the exhaust manifolds. If one has, you might be looking at replacing the wires, the coil, and the module as well.
Old May 6, 2009 | 06:52 PM
Lestrey08's Avatar
Engine: 2.8 V6
thx and yes i do knw where the codes are displayed but maybe i didnt wait long enough
Old May 6, 2009 | 07:39 PM
bevincarva's Avatar
also if pin 6 and 12 wont flash for you , and this might sound dumb try 5 and 12 , when i redid my interior wireing (20 years of beatin it to the ground will dod that) but i frigged up some where and crossed pin 5 and 6 meh but give it a try
Old May 6, 2009 | 08:08 PM
JJx91camaro's Avatar
Car: 1991 chevy camaro rs
Engine: carbed 350 sbc
Transmission: th350
sounds like it could be a map sensor also
Jeremys87
Jul 14, 2022 09:08 PM
Infested
May 22, 2018 11:56 PM
evilstuie
Apr 14, 2016 08:52 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
rsrmoore
Aug 7, 2015 08:44 PM
