please help, swap problem 2.8 to 3.4
Old May 5, 2009 | 10:20 AM
Noone's Avatar
Hi!
I came from Autria in Europe and we did an engine swap.
The base was a 2.8lt V6 Firebird Bj. 1987 MPFI Engine.
Now we did the engine swap to a Firebird 94er 3.4lt.
We did the swap like a thread in here.
Now here is the problem.
The 3.4lt engine runs great, but the hole car is vibrating.
We donīt know where it come from.
I have a automatic transmission.
We take the balancer from the 3.4lt???
We take the flywheel from the 2.8lt???
Also is there a big different in the oil filter housing.
the 2.8housings have 2 sensors in it, the 3.4only one.
We decide to take the 3.4lt housing.
Was this correct???
These are the three things we donīt know if it was correct.
Maby the vibration came from this???
Blanacer, flywheel?
We took a look at it , but they are in an good condition.
So i hope anyone can help me in this, and sorry for my bad english....
thanks alot
Martin
Old May 5, 2009 | 02:16 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: please help, swap problem 2.8 to 3.4
You should always keep rotating components (crank, balancer, flywheel, ect.) together, don't mix them up. You need the 3.4 flywheel. The oil filter boss shouldn't matter as much because it only needs the dummy pressure sensor (small one) wired in the fuel circuit so it'll kill the fuel pump if there's no oil pressure. The other sensor (large bell shaped one) is for the pressure guage on the dash if you have one.
Old May 5, 2009 | 08:37 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
All externals should be swapped from the 2.8. Flywheel/flexplate and balancer (internally and externally balanced is the difference), injectors, and thats about it, should be kept from the 3.4. everything else, use from the 2.8. I used the oil filter housing from my 2.8, no issues.
Old May 6, 2009 | 01:44 AM
Noone's Avatar
Hi!
Thanks a lot.
But the 2.8 Oil filter housing is different on the inside. The 2.8 has three pieces inside, The 3.4 has one.
I hope you understand me.
Is this correct to mount the 2.8lt Oil housing?
I donīt want no oil pressure in the engine...
thanks alot
Martin
Old May 6, 2009 | 06:52 AM
drdave88's Avatar
Engine: 6.0L
My 3.4 has the 2.8 oil filter housing on it, has since 04 with no issues. Itll work just fine
Old May 6, 2009 | 11:43 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My vote is flexplate for the vibration.
Also recheck and make sure all your mounts are tight.
Old May 6, 2009 | 01:12 PM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
I had the same exact issue except I swapped out the flywheel and all is well. I kept the balancer and flywheel that came with the 3.4 and it was a good thing I did.
The mistake I made was using the flywheel from the 2.8 and the balancer was from the 3.4. I pu tthe flywheel from the 3.4 on there and all is well.
(Didn't pay attention when I put the car back together so that was my mistake).
Old May 7, 2009 | 02:15 AM
Noone's Avatar
Hey Thanks all for the answers.
Yesterday with took the 2.8 Balancer on it.
The same Vibrations.
Nothings gonna better.
so now i have the 2.8 Balancer and the 2.8 Flywheel on it.
What do you think????
thanks alot
Martin
Old May 7, 2009 | 06:58 AM
ChevyCamaro1990's Avatar
Car: Camaro RS
Engine: 3.1l v6
thanks alot
Martin
I suggest putting the 3.4l balancer on it along with the 3.4l flywheel and see what happens
Old May 7, 2009 | 07:09 AM
Noone's Avatar
Hi!
I have no 3.4lt flywheel, my engine was an manual transmission.
And a flywheel cost in my country 100USD.
greetings Martin
Old May 7, 2009 | 10:32 AM
Noone's Avatar
Hi!
Another one:
In another forum i read that i must use the 2.8 water pump.
The 3.4 has another rotation.
Donīt know what that means, but is this so?
Must i take the 2.8 water bump?
thanks alot
Martin
Old May 7, 2009 | 12:08 PM
bl85c's Avatar
Car: '85 maro
Use the 3.4 water pump with the 3.4 timing cover.
Old May 7, 2009 | 12:12 PM
Dale's Avatar
Engine: 350 S-TPI
You need a 3.4 balancer, and a 3.4 flywheel/flex plate. Thats the only way your going to get rid of the vibration! Even if it cost alot.
Depending on which accessorys you used. I am assuming your 2.8 ones. You need the 2.8 timing cover, 2.8 water pump, 2.8 alt, 2.8 p/s, 2.8 a/c.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
