Vortec 4300 V6
Old May 7, 2009 | 12:02 AM
Stevobass's Avatar
Vortec 4300 V6
Is it possible to run the GM Vortec 4.3l V6 in my 88, or will I have to do some major fabrications? also any suggestions on ECU's to use with it?
Old May 7, 2009 | 08:06 AM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: Vortec 4300 V6
search.
Old May 7, 2009 | 11:01 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: Vortec 4300 V6
Its just about as much work as putting in a V8. A lot of people have talked about the 4.3 swap....but I am unaware of anyone who has actually done it.
I did a quick search with no luck. I know that there are threads on this...but for some reason they aren't coming up for me.
I would check out the engine swap section. There might be people there that can help.
Old May 7, 2009 | 01:12 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Re: Vortec 4300 V6
I read on here it's just like swapping in a V8. The engine mounts are similar. Like grimmics I can't find anything in the search.
Old May 7, 2009 | 02:24 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Vortec 4300 V6
what make/model is the 4.3 out of? i might have to try this
Old May 7, 2009 | 02:29 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Vortec 4300 V6
I know I read something about that too. It is a lot of work. It is very similar to the v-8 since it is a v-8 with 2 cylinders lopped off. Then there is always the question. If its so similar to swapping a v-8 , why not just do a v-8? If you have the 4.3 then it definately makes sense.
Old May 7, 2009 | 02:38 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Re: Vortec 4300 V6
I know they come in a lot of those work vans.
Old May 7, 2009 | 03:07 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Vortec 4300 V6
4.3 was ran in alot of GM rides. Montes, Buicks, S10's, Astros, Silvys, etc.
Can it be done, I'm more then sure it can be. Wouldnt be alot of work other then wiring and fabbing up some fuel lines.
Old May 7, 2009 | 03:42 PM
flakeh's Avatar
Car: 89 Firebird
Engine: 2.8V6
Transmission: t5
Re: Vortec 4300 V6
I'm looking at doing this swap myself. What I've gotten so far is...
-Need to use V8 engine mounts
-v8 radiator
-SBC bell housing for whatever tranny you use
Haven't done much looking into ECU's, As I plan on going carb'd with a turbo or a supercharger.
Pretty much its like a v8 swap. If you have the 4.3 already then go for it. But if you are buying the 4.3, just buy a 5.0 v8 and give yourself the extra ponies. not any more work.
Good luck!
Old May 7, 2009 | 10:27 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Re: Vortec 4300 V6
Stevobass, do you have the 4.3 already? Pretty much the same thing flakeh and Dale said, if you have it already, then do it. But if you've got everything for a V8 swap, why not trade that 4.3 for a good 305/350/383. Unless you're going power + economy, then again, how economical is the 4.3? I'm curious.
Old May 8, 2009 | 10:18 AM
project89's Avatar
Re: Vortec 4300 V6
any vorttec 4.3 will work, swap out the cpi manifold for a marine style port injection manifold (spider injector intakes cannot be boosted as far as i can tell and also require the stock ecm to run)
once u get a port injection manifold on it u could run the stock ecm reprogramed or something liek a megasquirt of dfi setup.
Old May 8, 2009 | 01:35 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Vortec 4300 V6
I have a 4.3 sitting around and oddly a ported m90 so what is needed because this may be a option down the road. When I pulled it out of the S10 all the sensors and wiring was like identical to the 305 tbi so that is easy enough but what about mounting?
Old May 8, 2009 | 10:27 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: Vortec 4300 V6
Since I have made a post in the sticky concerning this very question, I am going to lock this post. If anyone seriously starts this project and would like to make a blog about the conversion, please feel free to start a new topic, otherwise, please use the search function or read the various stickies at the top of the forum.
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
