running into some problems with running rich and buncha other crap need serious help
Old May 7, 2009 | 04:32 PM
Lestrey08's Avatar
Car: 84 camaro berlinetta
Engine: 2.8 V6
Transmission: 700 r4
89 camaro 2.8 mpfi running rich, stalling, wont let me get over 30 mph and gets horrible gas mileage my I've been told give it a tune up but my dad says the plugs are fine and i did only change them 6 months ago. plz help im sick of driving mom's mini van to work and school
Old May 7, 2009 | 04:34 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: running into some problems with running rich and buncha other crap need serious h
fuel pressure regulator is my guess.
Old May 7, 2009 | 04:43 PM
Lestrey08's Avatar
Engine: 2.8 V6
could it be any thing else
Old May 7, 2009 | 05:10 PM
sloick's Avatar
Car: Many
Engine: Several
have you done any of the really obvious things like... i don't know... check the codes and see what the cars telling you?
Old May 7, 2009 | 05:15 PM
Lestrey08's Avatar
Engine: 2.8 V6
yes im not a that stupid i tried to run codes with a jumper wire but no codes come up not even 12
Old May 7, 2009 | 05:34 PM
sloick's Avatar
Car: Many
Engine: Several
12 always comes up unless youre not doing it right.
Old May 7, 2009 | 05:37 PM
sloick's Avatar
Car: Many
Engine: Several
check vacuum lines to the regulator. on the newer cars if they are bad the lines fill with fuel.
Old May 7, 2009 | 09:10 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm getting this strange feeling of deja vu, kind of like I said what is in the above 2 posts in Lestrey's other thread... Could just be me, though.
Anyways, what kind of plugs did you put in? Did you actually check the resistance of your plug wires (10K ohms per foot MAXIMUM)? What color is your spark? Do you have raw fuel in the throttle body and intake plenum that is coming from a leaking fuel pressure regulator? Do any of your fuel injectors leak?
Old May 7, 2009 | 09:48 PM
sloick's Avatar
Car: Many
Engine: Several
okay, real simple. put a paper clip in you computer thingy under the steering wheel. the top right 2 are the correct ones. turn the key on, dont start the car, just turn it forward. the check engine will flash, pause, flash flash, and will do that a total of 3 times. (if it doesnt do this your computer is messed up, that issue needs to be dealt with before the rich condition can.) after the "12" (flash, pause flash flash) it will give you codes. write down the codes and look them up.
if the computer isnt telling you anything, then anything could be happening to cause the rich condition.
good luck.
Old May 7, 2009 | 11:21 PM
f-body animal's Avatar
Car: 85 IROC-z , 88 GTA
Engine: IROC 305tpi, GTA 350tpi
Transmission: 700r 700r4
Axle/Gears: IROC 308 10bolt gm/GTA 327 9bolt
alot of ecms fuses are shared with cig. lighter fuse if it is blown it will not give codes.
Old May 7, 2009 | 11:24 PM
check egr valve to see if it is sticking. if it is it sometimes makes car feels like it is falling flat on its face. or fuel filter.
Old May 8, 2009 | 05:59 AM
sloick's Avatar
Car: Many
Engine: Several
ONE of the many things suggested was to check fuses a long time ago. this car is a basket case.
Old May 10, 2009 | 02:39 AM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
First things first.
He needs to get the codes out to see, if there is something obvious wrong with the car AND to check that the ECM is actually working.
Doing anything before that is like shooting in the dark. There's no point.
Old May 10, 2009 | 08:30 AM
sloick's Avatar
Car: Many
Engine: Several
just remember what car it is...
Old May 11, 2009 | 04:47 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
x2 on that ^. You have to start with the codes. Mine has had some issues but no codes. My cig lighter fuse was blown. Maybe thats why there are no codes. So much useful info on here. All you got to do is read up on the older posts.
Thanks. My car is pretty crappy too but it shouldn't be for long.
Old May 12, 2009 | 10:18 PM
Engine: 2.7L V6
Axle/Gears: 4.41
There are only 2 fuses for the ECM... One is in the engine bay and also runs the fuel pump, this being the constant power fuse. If this one is blown, the engine won't run, end of story is that this fuse is good because the engine DOES run. The second fuse is the ECM-IGN fuse in the fuse panel. If this one blows, the engine won't run again because the ECM won't know that the ignition has been turned on.
Either this guy isn't pulling the codes right or the ECM has some major problems. There is a chart in the FSM for no codes, if necessary...
Old May 15, 2009 | 03:25 AM
Lestrey08's Avatar
Engine: 2.8 V6
thx but im srry whats the "FSM"
Old May 15, 2009 | 05:17 AM
molopaa's Avatar
Engine: 2.8 V6
Factory service manual
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
