a 10 minute intake set up how to
Old May 27, 2009 | 10:09 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
i have seen pictures of this on other cars so i thought i would share for some newbs.
1. pull intake off and pull air filters
2. their are 4 7mm bolts to loosen and 2 clips to get the air filter housing out.
- as for the clip just use pliers and take out the center, it will loosen the
whole thing enough to come out.
3. look down in the hole and there is a shroud in the way. 4 clips come out
like above
4. with a saw cut out the bottom of the air filter housing. just take out what
you need, the plastic is pretty brittle so a good sawz all will make life easy.
pictures:
Old May 27, 2009 | 10:10 PM
sloick's Avatar
Car: Many
Engine: Several
Re: a 10 minute intake set up how to
o yeah, sorry pontiac guys.
pic looking under the car.
Old Jun 5, 2009 | 12:17 AM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Some K&N filters will help open that up a little more. I did this to mine, and was surprised it made a big difference in throttle response.
Does anyone have dyno results after doing this? Only like a 2-5 hp difference, if that?
Old Jun 8, 2009 | 01:08 AM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
That worked well on my '85 Z28 also. Here is the setup I made for my RS. I used a 4" hole saw to cut a hole in the spot where the charcoal canister used to be. The filter mounts below that.
Attached Thumbnails a 10 minute intake set up how to-tn_full_imag0056jpg_thumbnail1.jpg   a 10 minute intake set up how to-3b02.jpg
apo_bailon15
Mar 28, 2016 05:20 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Bryan F
Aug 18, 2015 02:28 PM
mustangman65_79
Aug 8, 2015 12:07 PM
