89 Firebird "Slow Turn-over"
Old Jul 2, 2009 | 09:35 AM
vargasjc's Avatar
Hi,
I got a 89 Firebird with a 2.8L engine...the problem I have is that it takes a while of cranking and rotating before it turns over (usually about 3 seconds)...I am wondering...what could be causing this...
I have recently replaced the starter and the fuel pump&relay
It only has 80K miles and it runs great...just that starting problem
recently did a tune up on it too
Battery is only about 6 months old
Could it be because of a bad alternator? mine is pretty old
Any ideas WELCOME
Old Jul 2, 2009 | 09:38 AM
vargasjc's Avatar
Re: 89 Firebird "Slow Turn-over"
Sometimes it starts right away...but shuts OFF imediatelly...and I have to wait 3 seconds again of rotating before it starts again and stays ON
However, sometimes It starts right away and stays ON
But mostly is the 1st option (described on the opening thread)
Help me out ...
Old Jul 2, 2009 | 10:56 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Coldstart injector not working .
Old Jul 2, 2009 | 11:42 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I agree, the cold start injector could be the problem, I have the factory ACDelco alternator from 89 on my 89 Camaro and no problems.
Old Jul 2, 2009 | 11:52 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I also had problems with my car starting and I adjusted the IAC and TPS and it got much better still lags alittle but not much .
Old Jul 2, 2009 | 01:31 PM
vargasjc's Avatar
How do I do that? is it hard?
I work on my car but I have never heard of that...
I doubt its the cold start injector because it does it in hot weather too
Old Jul 2, 2009 | 01:41 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
IIRC the coldstartinjector is supposed to work when ever the coolant is under 90 degrees . I would check my timing and make sure it is 10 btdc then check the TPS voltage at idle it should be .54v and the IAC resets when you turn the key to on and jump the diagnostic port . If you do a search for how to do all this or get a Haynes repair manual it will tell you alot .
Old Jul 2, 2009 | 02:54 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I know my cold start injector is bad. any pics of its location? I'll search anyway.
Old Jul 3, 2009 | 12:57 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
How do you know if the Cold Start Injector is bad if you can't find it to test it???
You could just have a faulty Cold Start Switch.
Old Jul 3, 2009 | 07:27 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I agree there is a test that I can't remember off the top of my head but you have a coolant temp sensor that controls the cold start if it is bad the injector will not work or the plug on the injector is unhooked . The coolant sensor has a purple and a tan wire going to it and the purple wire gets power from the crank fuseand when the cold start switch/sensor is below 90 IIRC it closes and the cold start injector puts fuel in the intake for starting . The cold start sensor is located on the front of the intake by the throttle body and the cold start injector is located at the back of the intake and both can be gotten to from the driverside .
Old Jul 3, 2009 | 01:05 PM
vargasjc's Avatar
you got any idea how much that cold start switch is??
How hard it is to replace and where it is?
Old Jul 3, 2009 | 02:20 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
It is located on the front of the intake with a purple and a tan wire going to it .
PATRIOTIC1911
Northern Great Plains and Rocky Mountain
Oct 7, 2022 10:38 PM
Prodigious
Nov 7, 2020 09:23 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
pfsteichen
Feb 9, 2016 06:59 PM
sunbound
Sep 5, 2015 11:52 AM
