my 91 camaro RS 3.1l is over heating
Old Jul 19, 2009 | 05:43 PM
devin142's Avatar
Car: 1991 camaro RS
Transmission: automatic
Axle/Gears: 3.25
i just finished rebuilding the engine in my camaro RS and now when it heats up the fan will not turn on. when the temp on the gauge reaches about 200 the engine shuts off. also when i turn on the a/c the engine dies. please help
Old Jul 23, 2009 | 08:03 PM
vulcanravenxvg's Avatar
Car: 89 RS Camaro
Engine: fuel injected 2.8 6 cyl
Transmission: Automatic
Axle/Gears: Stock crap
Re: my 91 camaro RS 3.1l is over heating
Hey bro, that sucks. First thing I would do is check fuses. and the a/c problem is just as mysterious. i would say maybe some kinda short messes with the computer or something. just a guess.. i have no clue tho.
Old Jul 23, 2009 | 08:29 PM
devin142's Avatar
Car: 1991 camaro RS
Axle/Gears: 3.25
i checked all the fuses and i unhooked the heater fan and the a/c ran but the cooling fan still never came on and when the engine reached about 225 degrees the engine shut off
Old Jul 23, 2009 | 08:53 PM
Car: 89 RS Camaro
well i think the engine is supposed to shut off at a certain temperature. you should be happy it does. or it could be that when your fan goes to turn on there is some kinda short... and that kills your computer
Old Jul 23, 2009 | 09:18 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
sounds like your fans are grounding somthing out in the ignition. 200 is a good point to turn the fans on, and when they should come on it shuts the car off. ac on runs fan(s) and when you turn yours on its shutting the car off. i have no idea what could happened but that is my guess.
jhawkeye
May 25, 2022 06:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
92projectcamaro
Aug 6, 2015 01:20 PM
