Strange ticking noise
Old Sep 11, 2009 | 05:38 PM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
For at least a year now my Firebird has been afflicted with a strange ticking/knocking noise and I'm at a loss as to what it is. It only occurs when the car is moving and usually doesn't begin until 40+ mph. Once it does start though it can continue at low speeds down to about 10 mph. The frequency of the noise is dependent on the actual speed of the car not engine speed. Right turns seem to help get it started but not all the time. It seems to be coming from the front drivers side of the car but I can't tell for sure because that's where I'm sitting all the time.
Any ideas what this could be? Thanks in advance.
Old Sep 11, 2009 | 08:52 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Re: Strange ticking noise
loose wheel parts??? have you pulled the wheel off and checked everything out?
Old Sep 11, 2009 | 10:22 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
sounds like a brakepad slightly dragging. id check the brakes.
Old Sep 14, 2009 | 10:06 AM
87v6Bird's Avatar
Engine: 406, LB9
If it ever quits raining hear I'll look into that. I guess I could have something rattling around behind the center cap.
This doesn't really sound like a dragging brake pad to me. I could be wrong though.
Old Sep 15, 2009 | 12:37 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
front hub bearings worn......
Old Sep 21, 2009 | 10:45 AM
87v6Bird's Avatar
Engine: 406, LB9
Thought I'd let everyone know what the noise was. I had a loose wheel weight behind the trim ring. I could see where it had been able to slide around on the rim.
Old Sep 21, 2009 | 01:30 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Good find, did it take long to figure ? well done !
Old Sep 21, 2009 | 01:56 PM
87v6Bird's Avatar
Engine: 406, LB9
Luckily that's the second place I looked. First I took the center cap off and when I didn't see anything in there I took the ring off. I don't think I would have ever thought of a wheel weight as the cause of the noise.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
