could i have washed out the rings?
Old Sep 23, 2009 | 08:22 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
so about three days ago the car seemed like it was missing. it still started and ran ok, but just didnt have the same power it normally had. at the same time, my exhaust pipe broke off right where it joins the muffler. i had thought the loss in back pressure was causing the lack of power... i assumed if a cylinder had not been firing the car would barely run let alone start and not get out of its own way when accelerating
so earlier today i popped the hood to finally check to make sure nothing was out of place under the hood. wouldnt you know it, the drivers-front plug wire had become disconnected! i popped it back on, but have yet to take the car out for a test drive (im sure that it was the cause of the lack of motavation though). boy i wished i had checked that earlier
however, now im worried about the piston rings... think they have been washed out due to three days of gas being not ignited and getting in the cylinder? i only drove it to and from work... its about a 10mile round trip (30 miles total traveled in the three days id say)
Old Sep 23, 2009 | 09:11 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: could i have washed out the rings?
I don't think that would hurt it.
Old Sep 23, 2009 | 09:44 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Ehhh you should be good. Double check your compression and check your oil pressure. Obviously check out that spark plug after a day or so of a good run on the motor tho.
I mean its not good for the motor but I think you caught it soon enough. You werent racing around or shifting at like 5grand were you?
Old Sep 23, 2009 | 09:51 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
no way... since i could tell it wasnt running quite right, i would just baby it to and from work. 3k rpm shifts max
ive got new plugs/wires/cap/rotor for the car that i havent installed yet, looks like ill be doing that this weekend
guess ill find out tomorrow morning and throughout the next few days if its ok or not
thanks for the replies
Old Sep 24, 2009 | 04:18 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The engine itself is probably fine. However, I would be wary of the ignition parts being okay or not. Generally, if the plug wire is disconnected from the plug, the spark will eat through some part of the cable until it finds a suitable ground source, which will look like a light gray mark on the wire somewhere. Then you run the risk of the coil internally shorting to ground. And, without proper grounding, the module may end up getting damaged as well (don't ask how I know this, but it's from experience).
Old Sep 24, 2009 | 07:22 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
this weekend, probably Friday, ill be installing all new ignition parts (plugs, wires, cap, rotor) that ive had waiting for me to get the motivation to replace. looks like i found it
if i have time, ill change out all the fluids too, especially the oil since some gas probably made its way in there
Old Sep 25, 2009 | 08:27 AM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
Hah, I have done this myself. *shakes fist at cracked manifold!*
Old Sep 25, 2009 | 11:26 AM
SageMoonblade's Avatar
In the aviation community they actually dump raw gasoline into the oil systems to thin out the oil for starting in cold weather. When the engine comes up to operating temp. the fuel will evaporate out. As for hurting your rings I highly doubt it but if it did wash them out a little they will just build back up.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Numbah-1
Oct 2, 2015 08:27 AM
