Converting from VaraJet E2SE to 2SE ???
Old Oct 29, 2009 | 09:27 PM
pgtr's Avatar
Car: 84 Firebird: F41, Pwr, Instr Pkg
Engine: LC1 (V6 2.8L, 280k mi)
Transmission: MD8 (700R4)
Axle/Gears: GU5 (3.23)
I have a very original '84 FBody with 2.8L V6 (200k mi) and E2SE carb w/ computer controlled ignition etc.
I'm tired of dealing with the aging and convoluted end-of-carb-era emissions controls and am contemplating switching it out. Engine runs fantastic except for intermittent carb issues that I'm tired of dealing with.
I would change out the E2SE for a 2SE (early 80s S10) carb eliminating the mixture control solenoid, TPS etc.
I would also change out the distributor for a conventional vac advance distributor from an early 80s S10.
A few questions:
Q: Would the gas mileage be similar or comparable to my '84's current mileage (25 hwy)?
Q: Does the earlier 2SE carb still use the EFE pre-heat grid in the carb base gasket?
Qoes the ECM become a boat anchor or do I need to it's (removed) sensors?
Q: I think the EGR valve is computer conrolled - how would I hook that up (or should it be bypassed)?
Q: Will tbe cruise control still work OK?
...any other comments, inputs or suggestions regarding this contemplated project?
thanks
Old Oct 29, 2009 | 09:32 PM
mikey88firebird's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
Re: Converting from VaraJet E2SE to 2SE ???
if you got cruise and 25 mpg I dont know if I would change anything besides both those carbs are very very finicky
Old Oct 29, 2009 | 09:40 PM
project89's Avatar
A few questions:
thanks
u might be better off picking up an edelbrock manifold and puting a 2bbl or the holley 340cfm 4 bbl on it then swaping to another stock carb
Old Oct 29, 2009 | 09:56 PM
pgtr's Avatar
Q: Also can a Hi Perf HEI distributor for a modern 4.3L V6 work in my older 2.8L OK?
thanks
Old Oct 29, 2009 | 10:00 PM
pgtr's Avatar
200k mi and 25mpg has come with an increasingly high price of spending too many weekends/eves 'tinkering' on this carb. Finicky is an understatement.
By switching to a 2SE would remove a good % of the finickiness - I hope...? Thus my questions...
Anybody know on any of my questions above...?
thanks!
Old Oct 29, 2009 | 10:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
The 2SE is an awesome carb, before they screwed it up with CC control.
Only problem they all have is the sunken float after 20+ years that can happen. But a fresh carb rebuild should be done well before that can happen, should.
Doug Roe who desinged the Qjet for GM said some nice things about it in his performance book.
I can tell you an 85 is the last year you will find what ya need on an s10-s15
What I did, found a low mile one for cheap. $200, kid spun a rod bearing.
Cheaper then what a JY wanted for just a used carb n intake. And I know the parts all worked fine before hand.
Wasn't gonna spend $400+ on just a fancy aftermarket 4bb intake.
https://www.thirdgen.org/forums/v6/5...does-mech.html
"Well after some looking the 2SE is a nice carb, I can see how he gets 25 still.
The small 35mm main bores is ideal for fuel metering control at idle n part throttle, great for MPG/EPA but not performance. So the added 46MM bore with an air valve with a single metering rod. Metering control is governed by the air valve opening, So a sutiable mixture prevales reguardless of how far or "fast" the secondary is opened.
Now why is that a big deal, all them hooptie qjet mods to be able to snap all 4 wide open with out a bog, as the air valve can flop open to quick. Hence the needed of the vacum brake.
The 2SE doesn't need a vacum brake [has one though], with that gone and the tang that stops ya from going WOT at will, it gonna get a perferct does of fuel and respond like a deamon. Once the unneeded EPA added parts are removed."
Old Oct 31, 2009 | 01:28 AM
pgtr's Avatar
Thanks Gumby,
Q: Do the 85/older 2SEs also use the preheated EFE grid?
Q: In addition to a traditional vac advance distributor from an older S10 - what about EGR? My '84 Firebird's EGR has a rather strange EGR activation circuit that is computer controlled and the valve itself does not respond to simple vacuum being applied
Q: Does the ECM become a boat anchor that can be removed at this point? Or is it used for anything else?
Old Oct 31, 2009 | 01:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thanks Gumby,
Yea they have the heat thing but you can't buy em anymore if your is broken. Places only sell the regular base gasket without it. Which is good, I have no plans for using it, just like the TB bypass I did to my MPFI system.
Or the heat riser vale in my V8.
yep it has EGR, vacuum control like the dizzy, I plan to plug off n remove EGR. Only needed if you have smog checks.
And yea you don't "need" the ECM anymore.
Old Nov 1, 2009 | 11:47 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Dunno if your has an electric fuel pump, that may be a reason to keep the ECM, if ya don't wanna rewire.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
