Set timing on 2.8L carb engine
Old Dec 6, 2009 | 07:18 PM
algershick's Avatar
I see there is a tech article on checking the timing on a fuel injected V6, but how about a stock carb'd one? Are the procedures any different?
Old Dec 9, 2009 | 01:19 PM
molopaa's Avatar
Car: 83' Pontiac Firebird
Engine: 2.8 V6
Re: Set timing on 2.8L carb engine
Yeah, it's slightly different.
You won't find the tan/black or what ever color wire for the EST to disconnect. Instead you have to disconnect the 4 wire (IIRC) connector near the base of the distributor to disable the EST.
You should have an emissions label on the front of your engine bay that describes the procedure in detail. You're supposed to disconnect hoses etc. to eliminate the effect of the EGR and what not, but I haven't done all that when adjusting timing.
Don't really know how much it affects the adjustment, but my car has worked fine....
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
