rear coolant leak
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
rear coolant leak
pouring coolant from between transmission and engine. 99% sure its the rear freeze plugs. Are there any other locations that could cause a similar leak, just to check, like an intake gasket or anything?
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: rear coolant leak
If its pouring out, i would almost be positive its a freeze plug. I have the same problem, but mine leaks about a quarter size of coolant when the car cools down.
Im interested to see what some others say.
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
have you checked the fan switch? it's a sensor on the back of the passenger side head. my bet is still the freeze plug though. I've got my 3.1 sitting around I'll check what might do it tomorrow when it's daylight.
Engine: 5.0l TBI
I've got it up on the lift this morning, pulling the transmission to check. I'm sure its a freeze plug though. If it were the fan switch leaking it would run around the bell housing, not through it. But i'll check...
Car: 1988 Iroc
Engine: 5.7L
Is there a fan switch on a 350? Thats what might be leaking on mine.....
yea, there's a fan switch on a 350 but I'm not sure it's in the passenger side head. on a chevy small block I thought the fan switch was between plugs 1 and 3 or on the thermostat housing.
Engine: 5.0l TBI
It was all three freeze plugs, they had rusted out. I went ahead and did the complete block and thermostat. Now my car is throwing a code 15, which is coolant temp sensor. I'm not sure what could have happened to it, but it was fine before i started
. Replacing it tomorrow, we'll see what happens.
P.s. - its a 3.1l
. Replacing it tomorrow, we'll see what happens.P.s. - its a 3.1l
i was talking to camaro1185 about the 350.
sometime's weird things happen, i put the trans back in my talon and it wouldn't start because the fpr went out on it. complete other side of the car.
1992 Trans Am
May 10, 2023 07:19 PM
