bad ignition module
Old Jan 9, 2010 | 03:58 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
bad ignition module
so i took my dizzy out and had the module tested. it was bad. went to autozone and they said they had a new dizzy in stock. haha. they checked the box when i got there and it was the wrong dizzy in the box. (return) imagine that. module was under warrenty so i got a new module for free. installed it reset the timing every thing i needed to do.
ended up crushing the wire for the pickup coil w/ the cap..
needless to say im waiting on a new dizzy on order for my daily driver. boo.
Old Jan 9, 2010 | 08:57 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: bad ignition module
Why not replace the pickup coil . All you have to do is pull the dist. , knock the rollpin out of the drive gear , and then pull the shaft and then the pickup . Then you just reverse the removal process and your done . If you know what you are doing it can be done in 30 min or less . Not to mention cheaper than replaceing the dist .
Old Jan 10, 2010 | 12:03 AM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
all is under warrenty. lifetime warrenty ftw.
Old Jan 10, 2010 | 08:20 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
That works .
TheTraut88
Sep 11, 2015 05:16 AM
Amillionoh7
Sep 5, 2015 11:44 PM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
