Where o where does this wire go?
Old Jan 17, 2010 | 03:16 PM
musclecar201's Avatar
Car: 87 Camaro
Engine: 2.8l V6
Well, to be honest, I have no idea where this is really going to or from. All I know is that the wire was cut and put hot glue on the end of it and is just hanging near the alternator. Seems to come out of the back near the fire wall and into some convoluted tubing...I don't see a spot where anything missing or another wire so I'm not quite sure. Just wondering if anyone would happen to know where it goes.
Old Jan 17, 2010 | 05:11 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Re: Where o where does this wire go?
Do you have AC? is it an AC wire? I have a bunch of wires around in my car that I dont know where they go b/c the last owner removed the AC....
Old Jan 17, 2010 | 05:38 PM
Car: 87 Camaro
Engine: 2.8l V6
I removed the a/c myself, I didn't do this, it came like this when I bought the car.
Old Jan 17, 2010 | 05:41 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Hmmm.....let me go look at my engine....this is gonna bother me until I figure it out....
Old Jan 17, 2010 | 05:52 PM
Car: 87 Camaro
Engine: 2.8l V6
Thanks, the help is much appreciated, let me know if you find anything.
Old Jan 17, 2010 | 06:08 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Ok....I just went out to look, and I'm not really sure.
Yours is an 87 and mines a 90 so theres gonna be some differences.
Like your EGR vavle is vacuum operated and mines electronically, but there shouldnt be that much of a difference....
I took some pics so we can compare and see if we can figure this out....
Is there any markings on the wires? I could look up a wiring diagram and maybe figure this out based on the color of the wires on the inside of it, and of course and numbers or lettering would def. help.
Old Jan 17, 2010 | 06:09 PM
THEBEAST84's Avatar
Car: 84 z28 h.o./ 92 rs
Engine: 305 h/o /3.1 v6
Transmission: hybird turbo 350/t5 bog warner
Axle/Gears: non posi 3.73 / ls 3.42
i can look on my motor in the morning but i waz thinkin look around you map sensor or the back of the intake or theres a round valve on the passanger side lower heater
hoes i'll take pics tomorrow when it bright out ! GOOD LUCK
Old Jan 17, 2010 | 06:35 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
See anything? Sorry my phone takes shitty pics! haha My best guess is the wire on mine that goes into the connector on the support bracket for the alternator right behind it, know what I'm talking about? lol
Old Jan 17, 2010 | 07:18 PM
Car: 87 Camaro
Engine: 2.8l V6
I believe I don't have a map sensor as mine is the 2.8 its got tha MAF I'm going to have to look closer behind the intake when it stops raining.
I see the connector near the support bracket but that wire looks much bigger similar to a spark plug wire in size, mines about the size as the ground on teh back of the alternator and these other tha ti ahve highlighted, these could also be them. The writing was worn off ont eh wire so I'm going to have to really study it tomorrow.
Old Jan 17, 2010 | 08:41 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Does the HVAC system blow out of any vents other than the defroster, for one, and does it blow cold, for 2? That "wire" appears to me that it's either A. the HVAC vacuum system inlet running to the diverter switch in the control head, or B. the HVAC system heater control valve control tube, which directs vacuum TO the valve to shut the coolant flow off out of the heater core. If the HVAC system only blows out of the defroster (default safety position in the event of a vacuum loss), no matter what position the selector lever is put in, it's the vacuum inlet to the system. If the HVAC only blows hot air, or somewhat warm air (not completely cold at any rate), the "wire" is the control hose for the heater control valve.
I'm willing to bet that the reason for the hot glue on the end of the hose is that it's a either a vacuum source or outlet, and the glue is plugging it.
:edit: I'll bet it's the control hose for the heater control valve, which seems to be missing in your above pic.
Old Jan 17, 2010 | 10:30 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
1: Looks like something for the HVAC but I'm not looking at the car
2:Thats the vacuum line that goes into my MAP sensor I know that much
3: Looks like a line from the transmission to the radiator, either that or a fuel or brake line, its metal.
Old Jan 18, 2010 | 11:46 AM
Car: 87 Camaro
Engine: 2.8l V6
The HVAC blows out of all the vents it only seems to blow hot, I cant even get the temperature selector switch to move! I'm afraid to break it. I'll try and see if I can get it to move...
What you bet seems to be right as far as the idea goes, how would I go about finding the heather control valve...
1. Seems more like hte culprit than any of the otehrs I see.
Old Jan 18, 2010 | 11:49 AM
FireInMe17's Avatar
Car: 1990 Camaro RS
Yeah I agree
Old Jan 18, 2010 | 11:53 AM
racethesunlive's Avatar
Car: '92 Camaro
If its a hard plastic tube (not a wire but about the size of one) its the vacuum line for your temp. valve. Its a valve that uses vacuum from the HVAC system to divert coolant from your radiator over to your heater core inside your dash. The most likely reason the PO used hot glue on the end was to stop a vacuum leak from occurring when he removed the temperature valve. If you want to be able to switch from cold to hot you'll have to install a new valve and make sure your coolant lines are hooked up to your heater core.
Old Jan 18, 2010 | 02:04 PM
Car: 87 Camaro
Engine: 2.8l V6
You just nailed it my friend, I went out and looked, it is hard plastic and it turns out what I thought was hot glue the end melted, it seemed to have possibly come loose and melted the end causing this to happen, everything is still there like the heater valve.
However the Vac line is not long enough to make it reconnectable..., how would I go about replaceing or extending this.
Old Jan 18, 2010 | 02:14 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Just have to find out what part you need to get fron napa or where ever and get enough of it to re route it back to where it needs to go, youll have to trace it if you want to do it yourself
Old Jan 18, 2010 | 02:17 PM
Car: '92 Camaro
you can pick up new hard plastic vac lines at just about any auto store, they should also sell rubber couplers right next to the lines. If you don't want to trace the vac line all the way back (it goes into your dash in the front and can be a pain) just get a rubber coupler, clip the line somewhat close to the firewall, and add in the new vac line.
After your done you can test it by running your engine with the temp. set to cool. Once the engine warms up change to heat instead of AC and feel the hose going to the heater core, it should warm up to the touch (because of warm coolant flowing through instead of being off).
Let us know how it works out!
Old Jan 18, 2010 | 02:19 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
I didnt think of that lol
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
