super rich, causing two dead cylinders
Old Jan 22, 2010 | 02:12 PM
morrow's Avatar
Car: 92 Camaro Rs.R
Transmission: wc t-5
ok guys, hydro locked
we have had knarly rains for the past 4 days, i was on my way home and inded up going through 6 inches of water, it was down the street from my house, and it stalled, i fired it back up, ran fine kept on shoving at about 1200 rpm and 4mph, stalled again, hydro locked
i pushed it home and pulled all the plugs out and cranked it over a few times, cleaned the plugs and fired it back up, runs super rich
i put some new plugs in cuz i figure the old ones were fouled and still runs rough, did compresion test, all is good, so i figured ou two cylinders are not firing, it also hapens to be the two cylinders that had water in them, only about a spoon full of water came out when i cleaned out the cyclinders.
i also have a cool air intake and were my air intake temp sensor is located , it got water logged,
i pulled it out and water poured out of the sensor
im also thinken the oxigen sensor could be fouled also , all the cylinders are runing rich, only two are not firing, and im looking for other opinions
Old Jan 22, 2010 | 07:32 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: super rich, causing two dead cylinders
ok will the O2 is dead get a new one
change the air temp too
dry out the wires
and you should be fine
Old Jan 23, 2010 | 02:21 AM
morrow's Avatar
Car: 92 Camaro Rs.R
ok i picked them up tday so when this weather stops ill try it out
thanks
same thing i was thinken
hope it works
Old Jan 23, 2010 | 11:01 AM
morrow's Avatar
Car: 92 Camaro Rs.R
have you done this befor?
Old Jan 24, 2010 | 11:51 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Make sure you got all the water out... If the engine hydro locked, there should be a LOT more water in the cylinders than just a couple of spoonfuls, as that's barely enough to fill the dishes in the pistons. I might even go for new wires and cap and rotor as well... Check your spark on all the cylinders.
Old Jan 26, 2010 | 09:29 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Also probably a good idea to change your oil as well the filter. Don't want water in that.
db057
Apr 28, 2019 07:45 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Jk_Under
Sep 8, 2015 08:13 AM
Formula_88AE
Sep 3, 2015 01:47 PM
andy74
Sep 3, 2015 08:41 AM
