TURBOs fanilly
Old Feb 25, 2010 | 07:05 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
TURBOs fanilly
hey guy I'm finally getting this twin turbo v6 3.1 underway but i have some questions.
  1. do i need two Bov's because if it's one pipe to the throttle body ?
  2. Ok I'm running 8 PSI for now to i get the car fully rebuilt but sense i have two turbo would i have to divide the boost or is it still 8 on each?
  3. is the stock oil pump if i use a T fitting enough able to send enough oil pressure to both turbos and the motor under 5w30 in winter and 10w-30 in summer or should i go thinner?
  4. and how much oil pressure does a turbo need ?
Old Feb 25, 2010 | 11:13 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: TURBOs fanilly
1)No you only need one correctly sized one
2)8psi is still 8psi nomatter if it's 1,2,3, or 58 turbos. The amount of pressure they will develop together is dependant on manifold restriction, exhaust velocity/backpressure, turbine speed blah blah ect... Research your turbine selection.
3)What's the motor's condition? Independant lines are probably best.
4)Motor's pressure should be enough.
Are you doing this to your stock 3.1? What are you doing for fuel management? Details please.
Old Feb 26, 2010 | 12:24 AM
Car: 1992 firebird
Engine: V6
Re: TURBOs fanilly
sorry about the spelling i was in a rush in the main posting
the motor doesn't eat oil or anything I'm just confused on how to run the line to both turbo what do i tap or had on ?
well i got someone to turn the computer to read boost add gas retard timing the whole nine. I'm planning on 9-12 psi and i have a t3/t4 57 trim like in the sticky about turbos in the v6 section . I'm going with 28# injectors in a pertty much stock block.
Old Feb 26, 2010 | 04:43 PM
project89's Avatar
Re: TURBOs fanilly
if ur going to use twin turbos like in my sticky u better drop it down to twin t3's, or plan on running more then 8 psi the t3/t4s will surge like hell at low boost
Old Feb 26, 2010 | 06:01 PM
bl85c's Avatar
Car: '85 maro
Re: TURBOs fanilly
You might just tap off the oil pressure sensor port on the oil filter boss if you can't find anywhere better.
Old Feb 26, 2010 | 08:17 PM
Car: 1992 firebird
Engine: V6
Re: TURBOs fanilly
a t3 mmm is that a like the t27 they have on Ebay too ?
i was looking at a remote oil system to run form a 2 quart tank to the turbos and then drain back, and just cut the engine oil totally out but it's just where and how many psi do you need for a turbo?
well since I'm not building the engine to the summer time i was planing on low boost but project89, i seen u at karzyhouse customs when u dyno your car how much can these engines take before you need to fully build it besides the tune and the pistons im getting now ?
oo and where can i find some header for this i seen someone was making them but can't find the thread
Old Feb 26, 2010 | 08:34 PM
bl85c's Avatar
Car: '85 maro
Re: TURBOs fanilly
Just tap the motor. You'll need another pump and a bunch of stuff you don't really want for remote oiling. Pm firstfirebird about his header kit, although that's for a single.
Old Feb 26, 2010 | 08:40 PM
Car: 1992 firebird
Engine: V6
Re: TURBOs fanilly
ok tap the oil filter or the block itself and someone told me to add an oil cooler because single turbos ok but i got 2x the heat now
Old Feb 28, 2010 | 08:28 PM
project89's Avatar
Re: TURBOs fanilly
they sell knockoff t3's on ebay but they are junk, ur best bet is to get a set off of some older volvos in the junkyard, i would highly suggest sticking with a single turbo its much simpler that single t3/t4 you have will get you well into the low 12's on o properly built motor.i was building headers but my job has me moving around the country right now, im out in iowa and moving to pa in 2 weeks hopefully i will be able to stay in pa and if so i will start building them again
btw my motor runs a stock bottom end pretty much stock crank stock rods cast pistons just with good arp fastneres
Old Feb 28, 2010 | 08:39 PM
Car: 1992 firebird
Engine: V6
Re: TURBOs fanilly
but the whole twin turbo seem to be nice look wise i wasn't going to be a track heavy with this to like the summer when i can get my hand on a 3.8 motor oo yea twin turbo that bad boy. haha
Old Mar 1, 2010 | 09:30 AM
Car: 1992 firebird
Engine: V6
Re: TURBOs fanilly
after doing some math and pricing your right project89 its way easier and simpler to do one turbo just need to work out the placement and get the headers
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
