build ur own turbo headers
Old Mar 1, 2010 | 08:43 AM
project89's Avatar
here are a bunch of good pics of the turbo headers i built so you guys can copy them give me a few days and i will have measurements of each tube for ya. and after i get all the pics posted i will even post up a parts listing with prices for each piece of tubing and the flanges.
ill post up the part numbers for both the stainless and the mild steel eqiv from mc master car
first up the driver side header
this may clear the ac compressor i am not sure, i had removed mine before i even started
and here is the clearance in the car
now i know most of you guys wont have acess to a tubing bender as you can see both the driver side and passenger side headers have one runner with a sweeping bend these i bent myself in my tubing bender cause i didnt have enough 90* elbows when i do the parts list i will list the correct number of elbows so u guys wont have to worry about it
passenger side
this is the easy header
Old Mar 1, 2010 | 08:44 AM
project89's Avatar
Re: build ur own turbo headers
pretty much only need one pic for the passenger side but i have more if you want them just ask
Old Mar 1, 2010 | 09:00 AM
project89's Avatar
ok 90* elbows
you will need 11 of these
these are for stainless notice it says 1 1/4 pipe the inside diam is actually 1.442 inch and outside diam is 1.660
Part Number: 45735K217 $9.24 Each
http://www.mcmaster.com/#stainless-s...d-pipe/=611ngd
and some stright pipe
one 36 inch long piece should be enough
Part Number: 4347K342 $40.13 Each
http://www.mcmaster.com/#stainless-s...ttings/=611qsy
now im sure many of you are asking yourselves i know he said the stianless was very exspensive whys this stuff so cheap.
thie stuff i listed is 304/304L stainless hence why the wall thickness is .109 and not .065
304 stainless is not ideal cause it is prone to cracking but if the correct thickness is used and its welded properly it is fine, unlike the cheap ultra thin stainless headers sld on ebay for various cars.
ideally u want to use 316L or 321 stainless but even in 316L the prices for those elbows would go from 9 bucks each to around 35 bucks each
ill finish listing up some stuff in a lil bit
Old Mar 1, 2010 | 03:14 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
is that pretty much the only location to mount the turbo at
Old Mar 1, 2010 | 03:31 PM
project89's Avatar
no its not but u can put the turbo wereever you like by modifiying the crossover pipe anyway you want.my is now modified so that the turbo sits off to the side of the motor instead of out front like a grandnational type setup
Old Mar 1, 2010 | 04:20 PM
Drew's Avatar
When I think about stuff like this I kind of wish I still had my 3.1 Firebird.
Old Mar 1, 2010 | 06:34 PM
Pillsbry10's Avatar
id really like to try to tuck mine in where the smog pump used to be but i dunno if there is enough room. make it a little less noticeable thats its a turbo at first glance
Old Mar 1, 2010 | 06:39 PM
project89's Avatar
just flip the elbow on the passenger side header down and make the merge connectect on the top side
Old Mar 1, 2010 | 06:44 PM
Pillsbry10's Avatar
cant wait to get to the turbo...still a good ways off, gotta get the 3.4 to start first
Old Mar 4, 2010 | 10:55 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
ugh now i need to learn to weld add that to the long list of learn to dos
Old Jan 27, 2014 | 01:34 PM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
I think I'm going to give this build a go
Old Jan 27, 2014 | 01:39 PM
project89's Avatar
just a heads up if u dont have a tig welder u need to build them out of mild steel
u cannot mig weld the stainless steel
( u can with the right mig wire and gas but its not as strong and very ugly looking not to mention exspensive )
using mild steel u can weld the whole thing together using a cheap 80 harbor frieght flux core welder
Old Jan 28, 2014 | 05:28 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Some threads were meant to be resurrected. Nice.
Old Jan 28, 2014 | 05:32 PM
project89's Avatar
says the guy who posts up once every few years
u still have ur v6?
Old Jan 28, 2014 | 05:43 PM
TechSmurf's Avatar
Engine: LS1, Scrap
It's been sitting for a good long while in a different town... no chance to do anything with it. One of these days I swear I will bring the 3.4 home to refresh.
Old Jan 28, 2014 | 06:01 PM
project89's Avatar
wow hasnt ur car been down since like 2002 like way back when i first started with my turbo 2.8
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Feb 21, 2016 01:29 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
tricky1
Aug 23, 2015 01:17 PM
