vacuum line problem
Old Mar 11, 2010 | 02:42 PM
Beast_Mode's Avatar
vacuum line problem
i have better pics of the vacuum line i have a problem with. Its sucking in air.
The Red wire goes down and above it is the 2 black vacuum lines. The line to the Left is not connected.
The line to the right connects above the engine block.
Old Mar 11, 2010 | 03:00 PM
Beast_Mode's Avatar
Re: vacuum line problem
Distributor cap is top right....
below that is where the right vacuum line is connected.
Old Mar 11, 2010 | 05:31 PM
Drew's Avatar
One connects to the intake manifold, the other connects to the heater bypass valve near the front of the engine near the passengers side frame rail.
Old Mar 11, 2010 | 05:37 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Sounds like the loose one connects to the heater valve... Is the heat on constantly?
Also, I'd find a way to change how those spark plug wires in the second pic are run... Our factory sized wires aren't the best quality, and the vacuum hoses make good grounds when touching the aluminum of the intake.
Old Mar 11, 2010 | 06:13 PM
Beast_Mode's Avatar
no the heater isnt constantly on. but it works and so does the cooler.
Old Mar 11, 2010 | 06:20 PM
Engine: 2.7L V6
Axle/Gears: 4.41
What I meant was "Is the heater core constantly hot?" With that core bypass valve not connected to vacuum, the core will always have hot coolant circulating through it, so the air coming from the A/C will be less cold.
Old Mar 11, 2010 | 06:34 PM
Beast_Mode's Avatar
ok, so do you have in detail by where the core bypass valve is located
Old Mar 11, 2010 | 06:46 PM
Engine: 2.7L V6
Axle/Gears: 4.41
It's the round black thing with 3 coolant hoses attached to it that's right next to the alternator. The vacuum line plugs into the nipple at the top, which is facing the A/C box.
Old Mar 11, 2010 | 07:07 PM
Beast_Mode's Avatar
the arrow points at the area the vacuum line is. where is the heater valve at?
Old Mar 11, 2010 | 09:34 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Look to the left of the alternator in that pic, below the A/C accumulator. It looks like it might have SOMETHING attached to the vacuum input, but what that is is anybody's guess.
Old Mar 11, 2010 | 10:26 PM
Drew's Avatar
Yeah, you know... Down by the passengers side frame rail near the front of the engine. You could always search... The heater valve is pictured in several threads.
Old Mar 12, 2010 | 08:07 PM
Beast_Mode's Avatar
thanx. the original hose i joined it with an extra hose (same size) will the suction work as good then 1 long hose running to the heater valve.
Old Mar 12, 2010 | 08:11 PM
Engine: 2.7L V6
Axle/Gears: 4.41
That's the way mine is... The original factory line got melted to the exhaust somehow not too long after I replaced the valve the day after I bought the car.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
