Throwout bearing going bad?
Old Mar 20, 2010 | 12:13 PM
aviator84's Avatar
I recently replaced the clutch in my car along with the throwout bearing. Its been working great, but now I'm starting to hear a grinding/rubbing sound when I push in on the clutch. It only seems to happen when I'm shifting up to the next gear and when the rpms on the motor are up. At idle its fine, and if I shift into neutral while its making that noise it tends to stop. Because it doesn't do it all the time I'm not so sure it is the throwout bearing. I'm not sure what brand it is, it came with the clutch kit. What do you guys think?
Old Mar 22, 2010 | 10:13 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Throwout bearing going bad?
from what you describe, it sounds like its in the trans. a throwout bearing will make noise any time the clutch is pushed in, being in gear shouldnt have an effect on that. id think something in the trans maybe.
Old Mar 22, 2010 | 11:07 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Sounds like something in the trans itself. Have you checked the fluid level? If this has only been happening since you replaced the clutch, it may not be releasing fully.
Old Mar 22, 2010 | 11:22 AM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
i agree with 92 rs did you put fluid back in the trans after replacing clutch i believe you have to use 10w-30 motor oil in the trans...please keep us updated!
Old Mar 22, 2010 | 12:46 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
No, motor oil is not used in any T5 used in a thirdgen. NWC T5's use gear oil, and WC T5's use ATF
Old Mar 22, 2010 | 01:11 PM
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
looking at haynes they recommend 10w30 motor oil in t-5 trans ...dont shoot the messenger
not saying that haynes cant be wrong but thats what im looking at right this second
Old Mar 22, 2010 | 02:12 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
No bullets intended. I just didn't want him ruining his trans with the wrong fluid. I have seen 10w30 recommended on here before and always wondered where that came from. I have a Chilton's manual at home which is basically the same thing that I'll have to check tonight. I'm curious now as I"ve never seen engine oil recommended for any transmission.
Old Mar 22, 2010 | 11:58 PM
aviator84's Avatar
I'm currently running ATF fluid in my trans. That is what my haynes manual called for and when we pulled the trans. it was definately ATF that was draining out. When I replaced the clutch I did not replace the pilot bushing. The kit I had came with the incorrect pilot bushing, and I decided not to replace it b/c the old one didn't look/feel worn. I now think the bushing may be worn and is allowing the input shaft to vibrate when I let out on the clutch, and when the engine rpm's are up. The sound I'm hearing is a buzzing/rubbing sound and happens mostly when I'm letting out on the clutch, or revving the motor. I can feel a vibration thru the shifter when it is making this sound. Does this sound plausible?
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
rudolphschenker
Sep 4, 2015 02:41 AM
