Broken Timing Gear
Old Mar 26, 2010 | 08:08 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Broken Timing Gear
In May 2007, a bolt backed out of my timing chain damper and shattered my timing gear. October 2009, while I was driving, the same thing happened. I ran some simple diagnostics and determined that it wasn't a simple fix, so I had to devote all my time to getting my winter truck on the road. I just recently started tearing it apart, and saw this:
Now I'm unsure on why this one broke, I'm going to see the distance between the crank and the timing cover to make sure the crank isn't walking. I've also heard that the harmonics from pinging can cause damage like this (or worse). Either way I needed to replace my timing set, so I found this:
Cloyes Double Roller Timing Set So this weekend I'm going to install this as well as replace the oil pan and both front and rear suspension.
If anyone has any ideas why this happened, that would be great.
Old Mar 27, 2010 | 06:07 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Re: Broken Timing Gear
I installed the double roller today, and before I button it up I have a question. The timing chain damper does not fit with this style chain, the bottom gear's teeth are too big. The chain itself is pretty tight, especially compared to a stock chain. Do I need the damper? I talked to my dad who has built countless engines (pre FI) and he says the V8's don't use them. Here are some pictures:
Please, any help would be greatly appreciated.
Old Mar 28, 2010 | 04:58 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Thanks for all the help guys
If anyone searches this thread and needs an answer, I found the answer here:
https://www.thirdgen.org/forums/v6/2...ide-plate.html
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
