lets talk starters
Old Apr 13, 2010 | 11:26 PM
tenholewheels's Avatar
lets talk starters
i have a high torque ministarter left over from my v8 build but
my little 2.8RS needs a starter.
are these the same?
in other words will it work?
thanks wayne
Old Apr 13, 2010 | 11:30 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: lets talk starters
well it should but the you may have to use some shims it
Old Apr 14, 2010 | 01:44 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Nope. Won't work. The starter frame (where the pinion is mounted) is different between the L4, V6, and V8 engines. I believe that the V8 has straight-across bolts, while the V6 starter has offset bolts.
Old Apr 15, 2010 | 10:15 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
it could work because my v8 has offset bolts, it just depends on what bolt pattern it has
Old Apr 16, 2010 | 02:10 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Not gonna work....
You guys are forgetting that the tooth count on the flywheel/flexplate is different between the V6 and V8's. Can't just swap the flywheel too, because the mounting bolt pattern is different
Linson
Oct 24, 2025 02:00 PM
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
