MY LIVE BUILD THREAD
Old Apr 26, 2010 | 06:13 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
umm heres some pics of progress for right now ill type up more later
homeade cam install tool lol ( long intake bolt works great)
stock cam comming out
timming set
working late last night using a camping lantern for light
the start of the cam teardown
parts yay
remnoving timming cover
start of the day
-- project89
Old Apr 26, 2010 | 06:29 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Re: MY LIVE BUILD THREAD
You pulling the engine to get it freshened up and new bearings put in?
Old Apr 26, 2010 | 08:01 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
why not start with a 3.4?
Old Apr 26, 2010 | 08:25 PM
Engine: 3.8, 3.4
no this motor is tempoaray
he was g oing to get a 3.4 for the heads/cam/headers/ported intake to go on but it fell threw
he does plan on getting a 3.4 in the near future though to drop in he needs the car asap so thats why we just went with the new cam n topend on the 2.8 instead of waiting to find a 3.4 shortblock
btw heres some light body work to remove some rust i messed around with for him while was waiting on parts
well heres what iot looked liek before had already started some work on it
and after some still needs some blocking out and more primer
-- project89
btw car should be able to be fired tom 3rdgen lost 2 of the rocker nuts so have to pick some up first thing in the morning
Old Apr 26, 2010 | 08:41 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
What heads are going on that block? The stock iron ones? I dont think the 3x00 heads would work too well with those flat-tops. The compression would be comparable to a diesel lol
Old Apr 26, 2010 | 08:51 PM
Engine: 3.8, 3.4
yeah a set of my ported iron heads are going on it, i have his 3400 heads that i took in a trade for doing the port work and the install
-- project89
Old Apr 27, 2010 | 05:53 AM
Engine: 3.8, 3.4
You haven't seen the cam I was going to get, dynamic compression would've been 10 something, crower makes a god awful huge cam for the 60/6, If I ever wind up going N/A instead of turbo I'll get it, but probably more likely I'll go turbo, more headroom for max power, and a lot less hard on the engine than an 8k redline flat tappet solid cam and lifters would be.
As for the 3.4 block I will eventually swap one in when I have more time and money to do it, my DD needs work and is out of inspection atm, so I'm trying to finish the Camaro quick so I don't have to waste more cash on my POS buick century.
Old Apr 27, 2010 | 07:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'll get that CSI sent out Friday when the check has cleared, probably on my way to getting the OTHER ECM out of that '91 in the junkyard. (Don't know why it had 2, one on the harness on the floor and the other on the bracket under the dash, unplugged--didn't know it had the bracket under the dash and thought it had already been removed--may even get a free MEMCAL with it ).
BTW, since everything is still pretty much loose on the engine harness, could one of you guys take a measure for me between the part where the oil pressure unit and injector harness side of the harness meets up with the wiring from the throttle body (under the crank pulley) so I can get to fixing the 3.1 harness I bought off of a guy on here? I need the measurement between the injector harness connector and that union. I'm really going to have to give that guy some neg feedback on that one .
Old Apr 27, 2010 | 07:33 PM
Engine: 3.8, 3.4
sorry man didnt see this post till just now and got the car put back just enough together to get it running
videos will be posted soon
-- project89
Old Apr 27, 2010 | 07:43 PM
Engine: 3.8, 3.4
it lives sorta
-- project 89
Old Apr 28, 2010 | 12:14 AM
project89's Avatar
hey man if u need anymore help ggeting it back together just let me know but deffinatly get everything hookedup so u can break that cam in properly. ill get u a list tommorow of the final few tings u need to hookup and see if i cant get u some vacum hose diagrams.
if all else fails and u cant get it ill deff come help ya out again
Old Apr 28, 2010 | 12:18 AM
Engine: 3.8, 3.4
Alright, did you figure out what the deal was with my throttle cable? Or do I still need to figure that out?
Old Apr 28, 2010 | 12:22 AM
project89's Avatar
yeah its poped out were it comes threw the firewall if u trace it back from the tb to the furewall u will see it m u just need to pop the plastic piece back into the firewall all the way and then the cable will be right and let the throttle close fully
Old Apr 28, 2010 | 12:23 AM
Engine: 3.8, 3.4
Ah yeah I remember you saying that now, ok.
Old Apr 28, 2010 | 04:07 PM
Engine: 2.7L V6
Axle/Gears: 4.41
LMK if you need a diagram for the vac hoses... I have a hood from an 85 with the sticker on it. It's not exact because it's a Bird hood, but it should point you as to what goes where. It doesn't take long to snap a pic.
Old Apr 28, 2010 | 09:12 PM
project89's Avatar
im oing to set him up with a 3.1L vacum system layout so he can run his other tb ,alot of the factory 2.8 hard plastic lines were broken so it works out pretty well
bte those 2 pictures i posted few posts up are videos just click on them to watch them, car sounds pretty good with open headers and the cam from delta
Old Apr 28, 2010 | 09:17 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You wouldn't mind sending those 3.1 diagrams my way, would you? I don't think I have any, and the donor had them painted over .
Old Apr 28, 2010 | 09:22 PM
project89's Avatar
its pretty much the same setup as the 2.8 except the 3.1 dosent feed the idle air down to the back of the manifold the air is actually introduced behind the tb blade instead. so it has a diff fitting for the hose from the pcv to intake
almost everything else is the same except the egr is digital on a 3.1 so no vacum line,
id send u a diagram if i had one i just happened to prety much memorize were most of the hoses go
Old Apr 28, 2010 | 09:31 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I already knew most of that... I had to make a idle air pipe for the 2.8 parts because the idiots at the shop that dropped the 3.1 parts in decided to run the 3.1 PCV pipe and not the 2.8 one, plugging off the IAC OUTLET and causing me to lose idle speed control for almost 2 years. That was fun! Not to mention I had a heck of a time piecing things together since they left a good number of things disconnected (EGR, canister, cruise control).
I was, in particular, wondering just what connects to the rubber block on the TB on a stock 3.1... I'd go to the yard and find out, but the guy there is very **** about taking complete engines that are still "good" apart to find out what goes where (and, like I said, the PO of the harness donor decided to have the emissions and other stickers painted over when the car was repainted black). I can't even trade the upper 3100 plenum I have for one from a pre-96 car with the 3-solenoid EGR, even though most of those engines are junk (and there are a LOT of them in that yard).
Old Apr 28, 2010 | 09:34 PM
Engine: 3.8, 3.4
From what you describe that sounds like the CTS, it should have a 3 wire plug if that's what it is. A picture would help..
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
92GTA
Apr 9, 2016 07:39 AM
GTAman
Sep 21, 2015 09:57 AM
Matt86IROC
Sep 7, 2015 06:30 PM
