90 firebird stalls in gear at stop lights/ stop signs
Old Apr 30, 2010 | 08:50 PM
Csb41502's Avatar
I got a tune up done to it, had fuel filter changed. Ran great before the tune up. Still runs great besides dying at idle in gear. I've read thru other posts and seen it could be the iac. Can I unplug it and see if it still does it? Anything else I can try?
Old May 1, 2010 | 06:36 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: 90 firebird stalls in gear at stop lights/ stop signs
Unplugging the IAC is gaurenteed to make it stall. remove it and clean it off with some brake cleaner, keeping it upside down at all times.
I chased a problem like this around for a while, new O2 sensor, PCM, can't remember what else. Turned out my injectors were shorting out..
Old May 2, 2010 | 06:27 PM
Csb41502's Avatar
I checked out a bunch of stuff today. I narrowed it down to I think a bad brake booster or booster check valve. Once I pull the hose of the check valve and plug it the idle smooths right out and runs great. It's gotta be something little cause u can drive it all day and won't do it unless it's in gear with foot on brakes
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Bryan F
Aug 18, 2015 02:28 PM
