Are 3.1 and 2.8 fans compatible?
Car: 92 Firebird
Engine: 3.1 V6
Due to a fire I need a new fan for my 3.1 and I am wondering if the 2.8 and 3.1 fans are the same. Can somebody fill me in?
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Are 3.1 and 2.8 fans compatible?
I'm about 95% sure they are but wait for someone else to chime in...the engines themselves are identical in almost every aspect.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The fans are identical as long as they are electric and there is only one behind the radiator... 3.1 harness plugs into my 2.8 fan just fine.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
just get a replacement fan from a parts store should be about 30 bux. easy swap 10 min at the most.
Engine: 2.7L V6
Axle/Gears: 4.41
The upper bracket is different, yes, but the lower bracket just needs the rubber insulators moved. But it doesn't sound like he's worried about that (except maybe the upper mount).
