Engine lift
Old May 27, 2010 | 05:37 PM
Poptart's Avatar
Car: '91 Firebird
Engine: V6
Engine lift
Where are good points to attach lift chains to the v6 engine? I am aware there are lifting eyes but for some reason they aren't anywhere to be found on my engine. I'm lifting the engine to replace the oil pan and oil pump so I just need to lift it a few inches to clear the cross member.
Old May 27, 2010 | 08:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Engine lift
The lifting brackets should be bolted to the rear of the pass side cylinder head, next to your transmission dipstick (assuming a 700R4), or just to the rear of the coil bracket, and the other is bolted to the engine just over the driver's side exhaust manifold, hiding behind the A/C compressor. If someone removed them, you'll want to remove the accessory brackets and bolt the lifting chain brackets to the cylinder heads.
LT1Formula
20
Nov 14, 2015 12:02 AM
gta90
Sep 15, 2015 04:00 PM
NWAsonoma
Aug 18, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
anesthes
Aug 8, 2015 09:37 PM
