very high oil pressure on '88 camaro 2.8 v6
Old May 29, 2010 | 03:01 PM
Gigawatt88's Avatar
Car: 1988 Camaro
Engine: 2.8L v6
Transmission: 5 Speed Manual
Hello everyone
My camaro appears to have an abnormally high oil pressure, the gauge is pinned @ around 120psi both when running and when the engine is off, which is 40psi over what the maximum the guage is meant to say. obviously this has caused a great concern as it read 35 odd psi on average only yesterday
is there anything serious i should take a look at or is this a common thing?
thanks
Old May 29, 2010 | 03:16 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: very high oil pressure on '88 camaro 2.8 v6
this is the stock gauge i assume? the stock gauges are not very accurate, and are really for referance only and not the rear pressure. however, a wire could also be shorted/broken, causing the high reading, or the sender could be bad. Honestly, its probably just the gauge not working right.
Old May 29, 2010 | 03:24 PM
Gigawatt88's Avatar
Car: 1988 Camaro
Engine: 2.8L v6
yes, it is a stock gauge, i was thinking it might be a problem with the gauge or sensor seeing as half of the electrics have gone one at a time :P
cheers for the help, i'll get a mech gauge on the job
Old May 29, 2010 | 06:38 PM
Sheriff420's Avatar
Car: 91 Camaro rs
Engine: 3.1
I have the same issue in mine. The pressure was off the gauge and I changed the sending unit, now it reads 80 until it's hot, then after it gets hot it will read 30ish at idle and 80 if you bring the rpms up at all.
Old May 29, 2010 | 06:44 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Sending unit by the oil filter needs to be replaced. Thing with GM gauges is that when the sending unit or wiring between the gauge and the sender goes, the gauges will read high (as opposed to others which won't read at all). Stock calibration for the pressure regulator spring in the oil pump is 70 PSI. Yours probably read properly the other day due to a vibration or something temporarily restoring the connection to the gauge from the sending unit.
Old Jun 2, 2010 | 06:44 AM
Gigawatt88's Avatar
Car: 1988 Camaro
Engine: 2.8L v6
yep, turns out it was the sensor/sender, changed 'em and it seems fine now :P
cheers for the help all
Old Oct 17, 2010 | 11:32 AM
war2d2's Avatar
I have a 2.8 V6 with 80,000 miles on it. My gauge is all over the place. Sometimes reading no pressure at all, sometimes a 20/40/60, just depends on what it feels like doing. I've checked the oil level, it's ok; and I replaced the sending unit, no change...
Old Oct 17, 2010 | 07:01 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Check the wiring at the oil pressure sender. Sounds like a bad connection or broken wire. The white one in particular is the one that's got the problem.
Old Mar 8, 2011 | 08:35 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Thank you, for the great info. I will look into it as soon as I can get someone to get under it!
Old Mar 14, 2011 | 07:49 PM
RT66DAVE's Avatar
The guys are right one about the sender. Mine in my '88 did the same and the cause was the plastic case cracked inside the connector which allows oil to wick up and short out the terminals which causes no reading, high readings and unstable readings.
Old Jan 26, 2012 | 11:54 AM
90Firebird.V6's Avatar
My firebird has the 3.1L V6 and I just replaced the oil pressure sensor because the oil pressure was at 0, its fine now, but my oil pressure goes up to 80 and time the engine is warming up, or being operated, but occasionally when when its warm will be around 35-40 at idle, but the problem is, the motor oil drips and drops from the oil filter like a leaky faucet, I've replace the oil filter twice, still does it..
I did put 10w30 vs. 5w30 on the last change, but that's when the pressure was low, could it be the oil?..
Thanks in advance.
Old Jan 27, 2012 | 04:07 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The next time you take the oil filter off, make sure there isn't another filter gasket stuck to the adaptor. Also, check to make sure the adaptor bolt is in tight. There is a gasket and o-rings that can be replaced if everything else seems okay.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
ChevyZ71
Aug 13, 2015 07:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
