Distributer cap situation!
Old Jun 2, 2010 | 02:38 PM
89v6firebird's Avatar
Car: 89 firebird (v6) T-top.
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
I am left with the last thing in an attempt for the bird to run smoothley. I replaced the plugs and plug wires. my mechanic said to maybe replace ( i forget the name of it) its located underneath the rotor in the distributer cap. and see what happens when i do that. should i try that or just replace the whole distributer cap? (p.s im tight on $$)
Thanks.
Old Jun 2, 2010 | 06:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Distributer cap situation!
What's the engine doing that makes you think that either the pickup coil or the ignition module need to be replaced?
Old Jun 4, 2010 | 08:43 AM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
it stalls out. i have chabged the plugs and wires. so im going through systematically and fixin **** until i hopefully fix it. its either the gas or spark on the car. so im tackling the spark sistuation first.
Old Jun 4, 2010 | 09:12 AM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Does it just quit like you turned it of, or sputter and die. If its a hard kill, it could be the ignition module, the "thing" you mentioned under the cap. If it sputters, sounds like fuel. Did you replace the fuel filter?
Old Jun 5, 2010 | 03:12 PM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
it has two ways of stalling. 1). When i stop at stop signs, the RPMs just die down and it shuts off. 2). Im getting off the high way with the cluth engaged and it will shut off when the car is still moving. Its hard to tel whether its fuel or spark problem. So I Figure If i go through one area, and fix it up and something is still wrong I can narrow it down. idk what else to do. process of elimination.
Old Jun 5, 2010 | 03:15 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
do you still have a MAF setup? do you get a check engine light?
Old Jun 6, 2010 | 10:01 AM
Engine: v6 EFI
Transmission: IDK
Axle/Gears: IDK
Yea, is the AMF the computer? I do have a light and have had the code checked but it was something with emissions.
school boy
Oct 22, 2015 11:47 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
drumstixer
Sep 29, 2015 03:02 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
