Help me replace my pulsator
Old Jun 5, 2010 | 08:19 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I gotta replace my fuel pump pulsator. Its not hard to get to since its right undr the throttlebody. The only thing that kills me is that the aftermarket ones are threaded for the input and output and the stock oem is permanently connected to the fuel feed line. There are no threads to take the old one off and it seems you's have to get the whole line that goes from the fuel block to the rubbr fuel feed line. Question, if I got the right thread size, can I make a line using fuel injector hose with the right thread size going to the fuel block,pulsator and the rubber feed lines. I can't find anyone that can bend steel lines like the factory.
Ken
Old Jun 6, 2010 | 09:31 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: Help me replace my pulsator
pulsator don't sound like the right term. is it the pressure regulator?
Old Jun 6, 2010 | 10:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I don't care for rubber lines for high pressure fuel on the engine. I take it that the pulsator is leaking? It isn't really needed, although it does reduce the pump noise some.
Without looking at how the lines and such are run, just an idea. Remove the stock pulsator by cutting the lines, double flare the ends, and place a new piece of metal line in there.
If the lines are steel, which I believe they are, could use compression fittings. But my preference would be the double flares.
RBob.
Old Jun 6, 2010 | 04:52 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Yeah I haven't heard of one either...I'm guessing he means FPR or fuel pump relay, or It's just a part I haven't heard of.
As for my advice, just get a stock replacement, if no one sells them your best bet is to find a used one.
Old Jun 6, 2010 | 07:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
2.8 engines don't typically have one (not sure about the 88-89 ones, though). I still have my 2.8 fuel pressure line in the garage, but I'd rather just keep the pulsator thing on there. Actually, I think I tried to swap once and for some reason the 2.8 line didn't work...
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
