timing chain
Old Jun 6, 2010 | 12:41 PM
walkthelin3's Avatar
Car: 1987 camaro,88 firebird
Engine: 2.8 v6,5.0 tpi
Transmission: manual
Axle/Gears: 3.47
timing chain
quick question about timing chain. i have an 87 mpfi. what pullies are needed to be removed to get to the timing chain. i found out i have a stretched timing chain. and also. do i need to take the water pump off completely? or just the pully? any and all info about the installation of the timing chain would be of help
Old Jun 6, 2010 | 05:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: timing chain
i havent had to do this yet, but im pretty sure everything on the front of the engine has to come off to get the timing cover off
Old Jun 6, 2010 | 07:00 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: timing chain
Short list: A/C compressor, power steering pump (both with brackets), crank pulley and damper, water pump WITH timing cover (TC gasket set comes with gaskets for both the pump AND the cover AND a new oil seal if you got the right set). Then you unbolt the cam gear and slide it off, sliding the chain off of the crank gear and then pull the crank gear off with a puller. You do NOT need to remove the alternator or bracket, but you may want to at least remove the tensioner to gain access to the heater core outlet hose.
Of course, that all is for a car with a serpentine belt. Not sure about V-belts, but I think they're close to the same.
Old Jun 7, 2010 | 02:48 AM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: timing chain
You should have the room to do everything with a v6. I would take everything off (Alternator,Waterpump,Power steer pump) just remove everything off the front. Make sure to take a pictures and right down notes. Remove the center bolt off the pulley down below. You will need to buy or rent a harmonic balancer puller and installer. Remove the harmonic balancer. Remove the timing cover off. You will see the timing chain, now you will need a gear puller which you can rent from autozone. Make sure to remember where the dots are on the timing gears because they will need to go back there. You will want to buy all new gasket and just do everything in reverse.
Old Jun 7, 2010 | 04:41 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: timing chain
V-belts are pretty easy, water pump and pulley, crank pulley, I think PS pump can't recall for sure if the bracket bolts to timing cover or the block, alternator shouldn't be in the way, and for the parts, get the comp cams timing set from summit, $40, i was going to get one from autozone for convenience sake, they wanted $130 for the exact same thing, i had a good laugh at that...
Old Jun 9, 2010 | 10:19 PM
Axle/Gears: 3.47
Re: timing chain
autozone wanted 34 for the timing kit over here
Old Jun 9, 2010 | 10:22 PM
Axle/Gears: 3.47
Re: timing chain
thanks guys. hopefully il be able to get to it this weekend.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
