!986 firebird keeps frying computer
Old Jun 9, 2010 | 05:26 PM
transamrob86's Avatar
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Ok about 4 years ago my firebird got overheated and fried the head gaskets. I went to try and start it once after it had sat for a while and heard a loud pop through the speakers. I left it alone for a while, found a new motor, dropped it in and no go. Wont get fire. Pulled the computer and it had that nasty burnt electronics smell. I bought a new computer, hooked it up, tried startin the car and it started pouring smoke out of the computer.
I figure it might be a short under the dash because it did it before I pulled the motor.
So should I tear the dash out and start there?
Old Jun 9, 2010 | 06:12 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: !986 firebird keeps frying computer
Check the engine wiring first. Make sure nothing's shorting out on one of the exhaust manifolds, pinched in some reassembled component, all grounds are clean and tight, and that none of the solenoids has fried and shorted.
Old Jul 13, 2010 | 10:30 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
The thing is, the "pop" and no start developed before I even pulled the bown motor. It just sat for a good month or two from the time the motor went until the "pop"
Old Jul 14, 2010 | 12:07 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Open the computer and see what haprt of it has fried, you can narrow it down by what section fried.
each section of the board does different stuff.
Old Jul 14, 2010 | 07:19 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Here is a picture of inside the computer. Anybody got any idea what part it is that is frying?
Old Jul 14, 2010 | 07:43 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Looks like terminal A6... Which, according to the FSM, is a power connection running off of the ECM/IGN fuse. At least, that's the burned trace running next to the burned out driver chip there. As for what that particular driver chip does, there are others who would know that. If I knew why (what to look for inside the ECM to point me in the right direction) I kept blowing ECMs about every 2-3 years, I'd fix that problem as well (just blew another in March). The problem is either there, or A5/A7, which is SES light and TCC controls, respectively.
One of the things that will burn out a chip like that is a short to ground before a driven device. Like I said before, make sure no wires got melted and are rubbing together or against ground. You'll need to go through a good portion of the harness for this, as just about any wire could be doing this.
Old Jul 14, 2010 | 07:44 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Close but no prize, mine was buring out the chip just under it or in the middle the U15 chip, it was the CCP solinode on top of the charcoal canister was shorting out. Only found out as it was super hot to the touch.
But yours is different, id post in the ECM section with a title like
help ID this section of ECM buring out.
You can see where it say U14, U15, but don't see a U16, looks to be a U26 chip.
Old Jul 14, 2010 | 08:06 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
This is what mine looked like, Rbob the mod in ECM section was very helpful
Old Jul 14, 2010 | 08:10 PM
Car: 1986 Firebird
Engine: 2.8
Axle/Gears: 3.42s
Yikes! Yeah I have no idea what I am doing when it comes to his stuff. I dread looking through my wiring harness
Old Jul 15, 2010 | 11:14 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Take and disconnect the control solenoids, the EGR, canister purge, TCC, fuel injectors (test individually), fuel pump, coolant fan, and MAF relays, and check them with a DMM to make sure none are shorted out internally before checking anything else. For the relays, you want to check the coil circuits and not the power side, should be pink and green wires (I think).
Disconnect the ECM, if it's not still out, and ground terminal A5 in the small connector (the connectors are labeled on the back) with a test light. Turn the ignition on. The test light should not work and the SES should light. If the SES doesn't light, there could be a problem there.
BRoss99
Aug 10, 2025 05:08 PM
chazman
Aug 28, 2018 03:25 PM
E Rod
Aug 28, 2015 05:17 AM
chazman
Aug 22, 2015 02:01 PM
Bryan F
Aug 18, 2015 02:28 PM
