running rich
Old Jul 12, 2010 | 11:24 PM
garrettpen's Avatar
running rich
I have a 90 camaro with a 3.1 it will not stop running rich. the coolant temp sensor and oxygen sensor have been replaced and it is not setting a code. My question is what else helps determine the air to fuel ratio?
Old Jul 13, 2010 | 07:14 PM
garrettpen's Avatar
Re: running rich
Update: it doesn't do it all the time just when it gets hot. when it hits 180 its like somone flips a switch. it starts spitting and sputtering, it also smokes black out the exhaust. Anybody have any ideas?
Old Jul 14, 2010 | 11:37 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: running rich
check your fuel pressure regulator and also check your vacuum lines.
Old Jul 14, 2010 | 11:50 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
Re: running rich
whens the last time u changed the air filter? i would change it and do an idle relearn.
Old Jul 15, 2010 | 12:57 PM
garrettpen's Avatar
Re: running rich
It has a new filter how do you do an idle relearn?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
