help with 1991 firebird
Old Jun 21, 2010 | 09:18 PM
generalchase's Avatar
Car: 1991 pontiac firebird
Engine: 1991 3.1l LHO
Transmission: Th700r4
I got my 3.1l lho running the other day it idels kinda ruff and when i press on the gas pedal the car wil lgo into real low rpms and die if not let off. I think I didn't set it to tdc correctly is there anything else i should check?
Old Jun 22, 2010 | 07:30 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: help with 1991 firebird
Check the color of the spark plugs. Black is too rich, bone white is too lean. Either can be caused by a number of things. Is the ECM spitting out a code?
Old Jun 23, 2010 | 03:23 PM
the spark plugs are black
Old Jun 23, 2010 | 06:38 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Is the ECM spitting out a code? What's the fuel pressure (should be between 37 and 47 PSI when the engine is running, and 47 is on the high side). Probably a dumb question, but did you pull all 6 plugs? Were they all black? Also, what color is the spark at one of the plugs? You're looking for a bright white spark. Orange or red spark is an indication that some other part of the ignition system, either the coil, cap/rotor, or wires, need to be replaced.
Old Jun 23, 2010 | 10:40 PM
I just pulled the # one spark plug.I will check all spark plugs tomorrow. Fuel pressure is at 45. Distributor, spark plug, and, wires are all new. To check codes all i have to do is connect pin A to pin B Two top left ones on the aldl connector right. I will do that tomorrow as well. Thank you.
Old Jun 24, 2010 | 10:21 AM
Engine: 2.7L V6
Axle/Gears: 4.41
The ALDL pins A and B are the 2 in the top RIGHT, not the top left.
jhawkeye
May 25, 2022 06:33 PM
evan555222
Sep 20, 2016 02:51 AM
deracer
Apr 11, 2016 12:04 AM
wild1
Aug 27, 2015 09:01 AM
evan555222
Aug 22, 2015 07:14 PM
