Alternator overdrive pulley?
Old Jul 20, 2010 | 08:48 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Im looking into an underdrive pulley for my 3.4L, but already at idle my alternator doesnt charge enough and my radio turns off (Apline radio, it could just be the radio, I really dont know.) Also I could probably turn the idle up since it idles at 650rpm but I dont really want to change that. I found of Summit there are two different 6rip overdrive pulley for alternators. Would using a 25% underdrive pulley on the crank and a 32% (thats what summit says in the description) overdrive pulley on my alternator hurt my alternator over time? Or is it even worth buying the alternator pulley? How many other guys are running underdrive pulleys? Can you feel the difference in the butt dyno?
Heres the link for the pulleys :
http://www.summitracing.com/search/B...s/?Ns=Rank|Asc
Old Jul 21, 2010 | 12:08 AM
Smoke_Jaguar's Avatar
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Re: Alternator overdrive pulley?
I'd just go for a higher amperage alternator if it was me, shouldn't be all that much money and it'd probably last longer.
Old Jul 21, 2010 | 12:15 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
I would buy a larger one but the one I have is only a couple months old and works great.
Old Jul 21, 2010 | 12:26 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That won't make an alt put out more juice
AZ has the 105AMP upgrade alt for $60 or did at one time, it what I got.
plenty of juice for a system
Old Jul 21, 2010 | 12:30 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Actually, that the one I have. But I don't think I'm understood on my question, I only want to get the alternator overdrive so I can have the same about of charge I have now if I got an crank underdrive pulley.
Old Jul 21, 2010 | 07:12 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
bump!
apie2546
Oct 16, 2016 02:24 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
