v8 t5
Old Jul 26, 2010 | 01:46 AM
mikey88firebird's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
v8 t5
will a v8 t5 work in v6 87 bird and if so what clutch do i get
Old Jul 26, 2010 | 01:17 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: v8 t5
No it won't
Old Jul 26, 2010 | 02:22 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: v8 t5
Yes, actually, it will. You would need to get a clutch from an Astro van, or swap out the input shaft for one from a V6 (in which case it's better to get a V6 trans anyways). But, then, there is the chance of having mismatched speedometer gears, and finding the gears can be a pain. Especially for an electronic speedometer.
Old Jul 26, 2010 | 02:26 PM
Pillsbry10's Avatar
Re: v8 t5
lol sorry yes it will work after changing parts but i figured no was an easier answer... isnt it a diffrent bell housing as well
what are you looking to spend? did you call hawks? or any other site sponser? these trannys arent that hard to find for the v6
Old Jul 26, 2010 | 02:34 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: v8 t5
Differences between the V6 and V8 T5s are the bellhousing, input shaft, and in some cases, the stuff attached to the rear of the trans (torque arm mount, etc). We won't go into the NWC vs WC T5 debate...
Old Jul 26, 2010 | 02:48 PM
Pillsbry10's Avatar
Re: v8 t5
haha yeah please dont, most people wont even sell the non wc's. in most cases the v8 t5s are more expensive anyways so just find a v6 wc t5
Old Jul 26, 2010 | 02:55 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: v8 t5
Speedo gears for the VSS can be found cheaply on Ebay, http://allstategear.com or http://www.transmissioncenter.net/sp...n_______va.htm
You will need to change the bellhousing and clutch fork. I'm assuming you are reusing your original pressure plate and flywheel. The clutch disc may be hard to find due to the different spline count of the V8 input shaft. I know there is a disc that can be used to put a V6 T5 behind a V8 cause I'm running one now. I'm not sure if there is a smaller diameter disc that will fit the V6 pressure plate and the 26 spline input shaft of the V8 T5 though.
Old Jul 26, 2010 | 02:57 PM
Pillsbry10's Avatar
Re: v8 t5
350 bucks for a v6 t5 from hawks
Old Jul 26, 2010 | 04:55 PM
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Re: v8 t5
What are the differences in flywheels between the V6 and V8 engines? If the flywheels are the same, he should be able to use the whole V8 clutch-pack, right? I'm the guy selling this transmission to him. I agree that the World-Class T5 would be a better way to go. His money, though. I got this transmission cause the seller lied to me about it being a World-Class T5...when I didn't know any better. He will need the V6 bellhousing.
Old Jul 26, 2010 | 04:58 PM
Pillsbry10's Avatar
Re: v8 t5
the v6 and v8 clutchs are diffrent sizes
Old Jul 26, 2010 | 05:00 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
What about the flywheels? Can a V8 flywheel fit and work in place of a V6 flywheel?
Old Jul 26, 2010 | 05:01 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: v8 t5
While the flywheels are the same size I think, the pressure plates and clutches are different sizes. The clutch is not such a big deal. However, because of the different diameters between a V8 pressure plate and a V6 one, the bolt holes are in different locations on the flywheel. This means the flywheel and pressure plate have to match.
Old Jul 26, 2010 | 05:02 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
If the V8 flywheel will work and fit, then I can send him the flywheel, too. Then he'd just need to get V8 clutch-packs...
Old Jul 26, 2010 | 05:03 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
And the bellhousing...
Old Jul 26, 2010 | 05:05 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: v8 t5
Never mind. The flywheels are different diameters. The V6 flywheel has 148 teeth while the V8 flywheel has 153 teeth. So you'll have to use a V6 flywheel and pressure plate. The clutch disc would have to have 26 splines and be right around 9 1/8" in diameter. Plus or minus 1/8" shouldn't make much difference, but a V8 clutch is 10.5" in diameter.
Pillsbry10's Avatar
Re: v8 t5
you guys are really trying to make this harder than it needs to be...dont try to use v8 stuff it doesnt work. get a v6 tranny, call around they arent that hard to come across especially here around indiana kentucky and tennesse
Old Jul 26, 2010 | 05:09 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: v8 t5
While its true that its much easier to use the "correct" parts, sometimes they aren't available for a reasonable price or at all. And if he can't find one locally, shipping can run as much or more than the cost of the transmission.
I can tell you, when I swapped from a V6 to a V8, I kept my original V6 T5 because I couldn't find a reasonably priced V8 T5 in my area. 2 years later and I"m still looking.
Old Jul 26, 2010 | 05:13 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
I agree that the guy should go find a World Class T5, from behind a V6, in a junkyard. That way he could hopefully pluck the pedals, slave cylinder, and master cylinder. That's how I did it, and it still seems the best way...
But...I'm not gonna say "No" if he wants to buy mine.
Old Jul 26, 2010 | 10:01 PM
Engine: 2.8
Transmission: t5
Re: v8 t5
actually I found that you can do the swap you need a clutch disc from a 97 s10 4 cylinder, use the pressure plate,tob,and fork from a v6 and then you gotta find the pilot bearing with the correct id and od. the onlt problem is the money for all that stuff
Old Jul 26, 2010 | 10:03 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
LOL! Yeah...you're talking like four different clutch kits for one set of usable parts. NOT FUN.
Old Jul 26, 2010 | 10:06 PM
Engine: 2.8
Transmission: t5
Re: v8 t5
that is why budget flies right out the window with the uninformed and then our hobby gets a bad rap
Old Jul 26, 2010 | 10:12 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
Ugh...YEEEAAH. What ever happened to Natural Selection?
Oh, I just used the zip code you gave me on Car-Part.com, and found a 3.4L V6 with a 5-speed out of a '94 Camaro for $650. At a place called Lambert Auto Salvage in Booneville...about 67 miles away from you...it says.
Old Jul 26, 2010 | 10:14 PM
Pillsbry10's Avatar
Re: v8 t5
didnt we say to lol
it really isnt worth putting together some frankestein trans clutch setup for about what your gonna pay for the right stuff, and youll have less install problems
Old Jul 27, 2010 | 01:19 PM
Engine: 2.8
Transmission: t5
Re: v8 t5
thankfully i found a trans with bell and fork shipped to me for 250.00 big kudos to cm91rs1
Old Jul 27, 2010 | 09:05 PM
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Re: v8 t5
AWESOME! Great to hear!
Old Jul 27, 2010 | 09:09 PM
Pillsbry10's Avatar
Re: v8 t5
good deal
