Code 43 on a 1992 RS V6
Old Jul 28, 2010 | 08:10 PM
Beggins's Avatar
Car: 1987 Trans Am GTA
Engine: 355 TPI
Transmission: 700R-4
Axle/Gears: 10 bolt limited slip with 3.42
I am wondering what this code means.... the generic book that came with the scanner said EST. If that is correct any ideas ??? The car keeps dying then restarts no problem. Does it every couple of miles. Thanks for any info......
Old Jul 28, 2010 | 10:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Code 43 on a 1992 RS V6
Either the ECM, chip, or the knock sensor or wire down by the starter have crapped out. You need to disconnect the battery to replace the sensor because of the proximity to the solenoid and the positive battery cable. Replace the $40 sensor first.
Old Jul 29, 2010 | 05:46 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
and dont forget to drain your antifreeze or put a bucket under the knock sensor as fluid will come gushing out on your starter and your floor. it slipped my mind
Old Jul 29, 2010 | 06:22 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Only if you take the radiator cap off. I lost maybe an ounce or 2 when I did mine last year. The cap and the rest of the system creates a vacuum that holds the flow back (similar to keeping the brake fluid cap on the master cylinder when you gravity bleed the brakes... doesn't work).
BumpaD82
Feb 26, 2016 02:57 PM
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
Shane87irocz
Sep 22, 2015 06:21 PM
steimel94
Sep 20, 2015 12:46 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
