V6 Swap Question
Old Aug 6, 2010 | 01:04 PM
dturn2110's Avatar
Car: 1989 Camaro RS
V6 Swap Question
I have a 1987 Base Model Camaro Auto with no engine and a 1989 RS with a 2.8L 5 speed. I was thinking about swapping in the 2.8 and 5 speed, but I wanted to know if the engine would just drop in or if I would need to do some modifications. I'm not sure if there is more information about the cars needed to answer this I'm new to the third gen world. Any help is appreciated.
I noticed the sticky above mentions that the 2.8 and some others are the only direct bolt ins into 3rd gen f bodies, I just wanted to verify that the difference in years caused a problem or anything.
Old Aug 6, 2010 | 01:35 PM
Pocket's Avatar
Car: 91 Trans Am
Re: V6 Swap Question
Youll have to change the body connector pinouts with the 89 harness to match your 87
To get the trans to work a hole needs to be cut, pedals hung and clutch related wiring modified
Physically it should go right in, but for the amount of trouble Id suggest checking out the engine swap forum
Old Aug 6, 2010 | 01:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That all depends on if the empty car has the frame mounts for the V8 or V6, and the front springs as well. If you drop a 6 into a car that has V8 parts, you'll need to swap the mounts and the springs or the front will sit too high. You may also want to swap the auto trans mount to the T5, as it's way cheaper to replace when it does bust, and there is less hassle getting it in and out as opposed to the manual mount. And, you will need to rewire some of the dash to produce the VATS fuel control signal if your car has the key with the chip in it, or the engine won't be running anytime soon.
Old Aug 7, 2010 | 01:23 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
If it's an 89 donor, wouldn't it be a 3.1? Thought they switched for that year to the 3.1...
And yeah...the amount of work really depends on which engine was in, and what is going in, if you're going from a 2.8 to a 2.8, the extra work will be quite nominal. I've never done a trans conversion but I'd imagine its a bit of work.
Old Aug 7, 2010 | 08:49 AM
Pocket's Avatar
Car: 91 Trans Am
Trans conversion is one hole cut and 6 wires reran
BTW, 90-92 cars were 3.1's. They changed with the ECM going to speed density
Old Aug 7, 2010 | 10:41 AM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
two holes cut, master cylinder and trans tunnel other than that yeah its pretty easy, i only wired the neutral safety switch from the auto. i bypassed the clutch switch and have yet to put the reverse lights on
Old Aug 7, 2010 | 02:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And the 87 has a cable speedo, so you would have to find a mechanical speedo drive (which I happen to have in my spare parts bin). That's 4 wires to rewire (reverse light switch and clutch start switch, no electric VSS on the 87).
Oh, and if you still have a wiring harness for a V6 on the 87, you don't need to rewire for the VATS fuel control signal. Otherwise...
Old Aug 7, 2010 | 03:07 PM
Pocket's Avatar
Car: 91 Trans Am
Both are pre-90 camaros, both will have a cable speedo
Old Aug 7, 2010 | 03:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Some Camaros had the electronic speedo in 89 .
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
