Vacuum Diagram N Engine Components Locations
Old Aug 15, 2010 | 12:53 AM
berto85's Avatar
I need some help, I'm trying to pass smog and I was using one of the diagrams that was posted here, I just bought this 83 firebird, and I was trying to fix the vac hoses but it look like I had extra hoses and hoses un unplugged so I dont know what is suppose to go where, I never worked on a car before so I'm a lil lost, I follow the diagram but I see that I have extra hoses, n there are like outlets where I can plug those hoses, but I dont know where to connect what, since they dont appear on the vac diagram for my 83 2.8L 2BL firebird, is there a diagram that shows all the parts under the hood? Please Help Me
This is my carburetor
What is this? this are something on the left side of the carburetor they both have two outlets to connect some vac hoses but I dont know how to connect them, because on the diagram shows that they have only one outlet
Size:  191.1 KBName:  SNC00010.jpg
This is the air management valve, but it was 2 outlets on the top and a hose that is coming from the bottom and I dont know where they go
this is the vac sensor but as you can see it has 3 outlets which I dont know which one I'm suppose to use to connect it to the carburetor
this part I dnt know what it is, it is located between the carburetor and the air injection pump,
Old Aug 15, 2010 | 11:55 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Vacuum Diagram N Engine Components Locations
Don't know all of them. Looks like one of them could be a cruise control modulator that's missing both hoses (the one with 2 hose connections). That thing you call the vac sensor isn't the vac sensor... Don't know what it is, but the vac sensor is another name for the MAP/BARO sensor, which is used on most FWD V6 cars and has only one vac connection. And the last thing is what they call a temperature controlled vacuum delay valve, which opens at a certain coolant temp to allow vacuum to flow somewhere. May be known as an EGR or spark delay valve, to prevent the engine from stalling at cold temps by not allowing the EGR to open until the coolant reaches a certain temp.
Old Mar 21, 2015 | 06:15 PM
OrangeBird's Avatar
Car: 1989 Firebird
Infested
May 22, 2018 11:56 PM
NinjaNife
Aug 23, 2015 11:49 AM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
