Smoke headlight covers
Old Aug 17, 2010 | 12:28 PM
TeddyMedina's Avatar
Car: '89 Camaro RS, '68 Camaro RS
Engine: 2.8L [89] , Crate 5.7 [68]
Hey guys I have an 89 RS, when I go on ebay I find some smoke headlight covers that are around 35$, the descriptions say for the IROC and z28's only, and "not the regular camaro". It seems to me like the dimensions of the lights are the same between iroc and rs.
I'm asking this because "RS" covers go for 50 to like 100$
Anyone know anymore about this? Can I use the "IROC/z28" covers?
Old Aug 17, 2010 | 04:06 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Smoke headlight covers
I think that it doesn't matter, pretty sure we all have the same headlight pockets, but on the other hand I know the grille/nose did change a little from year to year, but post this in the "Body" or "Auto Detailing and Appearance" this section is for engines.. you're a lot more likely to get answers over there, in fact I wouldn't doubt it if its already been answered, try a search on them.
Old Dec 26, 2010 | 08:07 PM
89sleeperiroc's Avatar
Car: 1989 iroc
Engine: 5.3
Transmission: 4l60e
Axle/Gears: GM 10 bolt 2.73
i do have two questions one what kinda speed will these thing hold up to and two what kinda inproivement will i see in the quarter mile or gas milage
Old Dec 26, 2010 | 08:21 PM
Drew's Avatar
Back when they were popular it was common to hear about them flying off at highway speeds.
Zero improvement of any kind, they're strictly cosmetic.
As for the original question, the 1988 Sport Coupe, 1985-1992 RS/Z28/Iroc front bumper is all the same piece so the headlight covers should be the same. 82-84 Z28, and 82-87 Sport Coupe use a different front bumper cover and probably will need a different cover.
Old Dec 26, 2010 | 08:34 PM
AmorgetRS's Avatar
I had a clear pair for about 2 weeks before they both flew off. Not worth it.
Old Dec 26, 2010 | 08:54 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
where did u get the clear ones from?...
Old Dec 26, 2010 | 09:10 PM
AmorgetRS's Avatar
Summit I believe. They list them for only 91-92 Camaros, but I'm not aware in any size changes in the headlight holes.
Old Dec 26, 2010 | 09:18 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Should just trade up for a Firebird.
Its lack of daytime windjammer lights adds 5-10MPG and a full 2 sec in the quarter miles.
That’s what greased up deaf guy said.
So you know its true
classic industries is a good place to find stuff like that.
http://www.classicindustries.com/
Old Dec 26, 2010 | 09:21 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...
Old Dec 29, 2010 | 09:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL hopefully I've got some of that 1982 TransAm wind-tunnel-testing in my '86...
Old Dec 29, 2010 | 10:48 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
LOL these covers look BADASS ... When they're actually still on the car
No but seriously, I am on my 4th set and they are not on the car as I have not figured out a way to install them yet because my last 3 sets flew off on the highway! Sometimes I was going 100mph, sometimes I was going 60mph.. Once I went 110mph and they were still on good..
Ultimately, you would probably need to drill a hole in the bumper and fabricate some sort of bracket that would bolt it in place. I was thinking of sealing it around the edges but it might look like crap.. Maybe using more of those little black "L" brackets to hold it in place? I don't know but they need to make those brackets on the side (the straight ones that are on with adhesive) stronger because they always snap under tension (from the wind, bumps, etc.)
Old Dec 29, 2010 | 03:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Lots of those metal tabs and some clear silicone would be good to glue them down, but still come off if you had to. Sticks well to a smooth surface. Think fish tanks, smooth glass holding tons of water, with just a ting bead of silicone on the edges.
Though wish someone would re-pop the Firebird ones and have em look right like on KITT, smooth edges which has to mean the plastic is beveled to start, n still probably need a final hand sanding to make it fit tight to a nose. only ones made aren't even beveled to start, making so much work, cheaper to make your own.
https://www.thirdgen.org/forums/body...rn-signal.html
db057
Apr 28, 2019 07:45 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
sylentnite
Sep 9, 2015 02:55 PM
Accerrito22
Sep 5, 2015 09:34 PM
luvofjah
Sep 3, 2015 07:08 PM
