need help with 2.8 freeze plug
Old Aug 20, 2010 | 02:27 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
it is easy to see its on the pass side and you can see it right behind the starter
I have to put a new one in
anyone got any suggestions or tips
I need to have this camaro back to these people
Long Live Thirdgen
Old Aug 20, 2010 | 02:47 AM
Heavy_Chevy's Avatar
Re: need help with 2.8 freeze plug
i'm not really sure 100% but with most freeze plugs i've known to go out i replaced with the rubber ones that you press in and tighten and it seems to work pretty well.....just my 2CENTS
Old Aug 20, 2010 | 07:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Hit one side of it with a punch until you can pry it out AFTER you have drained the coolant. Then, put one of the same type in its place. The rubber ones are only temporary and will probably break through at the worst possible time. However, first, make sure that the block hasn't cracked around the plug.
Old Aug 21, 2010 | 06:17 AM
jamon8's Avatar
Engine: 350 tpi
used a long extention and beat it in
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
Zane Story
Oct 8, 2015 12:40 PM
89 formula TPI
Sep 7, 2015 11:06 AM
rjcme
Sep 5, 2015 01:23 PM
