engine harness help
Old Sep 16, 2010 | 08:39 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
engine harness help
Iv been on the hunt for a new 2.8 engine harness since mines alittle cut up by the PO and its missing a few connections like the windsheild wiper connections. Well i found one off an 85 camaro 2.8 auto with v belts, but this guy also has one off an 87 2.8 with a serpintine belt setup and its a manual, which is better or can i even use either one? do i NEED an 86 harness?
Old Sep 16, 2010 | 09:13 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: engine harness help
Doesn't have to be an 86 far as I know, but if you have an automatic you cannot use the manual one because it won't have a connector for torque converter lockup, less you don't mind losing that. Otherwise, check that the 2.8 has the same stuff, ie. vacuum operated EGR valve, same type of throttle body and TPS, IAC sensors etc., but honestly unless the one you have is really bad I would just patch it up...wiring harnesses are a PITA, especially when nothing is hooked up.
Old Sep 17, 2010 | 10:45 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
What connections are you missing? I have what amounts to a whole harness that's cut up, including the older wiper motor wiring (also have the motor).
Old Sep 19, 2010 | 09:20 PM
Engine: L31 350
i got the plugs for my windsheild wiper moter, im going to go through and fix where the PO hacked it.
Old Sep 19, 2010 | 10:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Don't use butt connectors and do it half-baked. Get some heat shrink tubing and a soldering iron and do it right so you don't have to do it again later.
Old Sep 20, 2010 | 01:44 PM
Engine: L31 350
already planned on it, i know that we get some water under the hood so i dont want my wipers shorting out
Old Sep 20, 2010 | 07:49 PM
Engine: 2.7L V6
Axle/Gears: 4.41
And, if you can find it, there's heat shrink out there with sealant inside, generally used for Ford repairs (one of very few things they got right). Use that if you can.
Old Sep 20, 2010 | 07:56 PM
Engine: L31 350
should i put the black tubing back over it after i do this?
Old Sep 20, 2010 | 07:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, it keeps the wiring from scuffing and other damage, even though it seems almost worthless, especially if the loom (the tubing) is falling apart.
Old Sep 20, 2010 | 08:00 PM
Engine: L31 350
will do, thanks dan
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
