91 firebird runs rough, smell gas
Old Sep 26, 2010 | 04:23 PM
dakotacdy1's Avatar
Car: 91 firebird
Engine: 3.1 v6
Transmission: automatic
Hey, im new to this site but i have read some posts from people who have had the same problem as me. my mom lives in Ohio and she gave me her car when i arrived there she told me that it died about 3 months ago, she had plugs put in it and it ran for another month, she put plugs in again and it ran for a week and a half, then she just parked it. I put a HEI module, coil, cap, rotor, and plug wires on and it started right up and ran great for 2 or 3 days then it dies. Pulled the plugs and they were soaked with gas so i cleaned them and drove it back to the house. Put a temp. sensor and a MAP sensor on and ran great for a week then it died again. I it will run for bout 5 to 10 minutes then it will die. If you idle it up it will die like it has no power at all. I could really use some help, any suggestions would greatly be apprieciated.
Old Sep 28, 2010 | 06:30 AM
jiyasa's Avatar
Re: 91 firebird runs rough, smell gas
Just had the same problem since may, mine's a 91 3.1L V6 too, check the fuel injectors. Probably why you're smelling the gas, it's probably dumping gas because an injector is bad.
Old Sep 28, 2010 | 06:59 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
My guess is on the fuel pressure regulator.
Old Sep 28, 2010 | 08:29 AM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
I would check both, the fuel injectors and the fpr.
Old Sep 28, 2010 | 10:07 AM
southbay08's Avatar
When there is a question of leaky injectors we recommend pulling the plugs...if you
have wet cylinders you have leaky injectors, but you can also check the fuel pressure regulator and the diaphragm.
Old Sep 28, 2010 | 10:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you're pulling enough gas in the cylinders to foul out all 6 plugs, my guess would be that the FPR diaphragm is shot and it's shooting gas right into the intake. Pull the intake bellows and open the throttle plate. If there's gas pooled behind the plate, the FPR is toast. You can get a replacement FPR diaphragm, but you need a security T10 torx to remove the screws on the cover.
Old Oct 16, 2010 | 12:21 PM
dakotacdy1's Avatar
Car: 91 firebird
Engine: 3.1 v6
thanks guys i will check both of those as soon as i get a chance. Just got done putting a timing chain in my sisters firebird. Thanks again
customblackbird
Aug 15, 2021 10:16 PM
bryan623
Mar 22, 2021 06:43 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
