Injectors
Old Oct 5, 2010 | 12:02 AM
donnas88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Injectors
I am redoing the top gaskets on my camaro. I was wondering if installing the aftermarket injectors are worth it? Do you have to change the ecm to accept the injectors? has anyone done this? Thanks
Old Oct 5, 2010 | 01:42 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: Injectors
I don't think it's worth the money unless your going to SC, or turbo it later. I have the 3.1L injectors on my 2.8, not a difference. If you want to it's you, but I wouldn't, unless I'm gonna be using a power adder.
Old Oct 5, 2010 | 03:57 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Injectors
I would. The stock injectors are prone to both clogging and shorting out internally. The Ford 2.9 injectors have been a popular swap lately.
Old Oct 5, 2010 | 11:36 PM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Re: Injectors
Thanks guys. The ford 2.9 injectors will fit in? I wonder if if its a big differnce in power? Thank you again.
Old Oct 6, 2010 | 08:34 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Injectors
There is no power difference in the 2.9 injectors (basically a stock replacement with different injector guts). There's a thread called "The Best Injectors For V6" if you want to look it up in more detail.
Old Oct 6, 2010 | 11:52 PM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Re: Injectors
Thanks again....Will chec k it out.....
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
