badist of the bad
Old Oct 18, 2010 | 04:31 PM
  #51
overide's Avatar
Re: badist of the bad
Originally Posted by LT1guy
Yeah, a cracked head prompted the last major re-do; I had everything out. The whole drivetrain, wiring, plumbing...all of it.
wonder if that would explain the seeming low hp dyno numbers compared to the other guys...the car had to be loosing compression? From what I remember posted here and there the car always had strong TQ, but never hit the HP numbers
Old Oct 18, 2010 | 05:55 PM
  #52
LT1guy's Avatar
Car: 1987 Trans Am
It definitely must have been hurting the HP, but I think the real issue was the tune. It was pig rich. Trueleo supplied a couple of chips, but they were never right (we didn't have the capability to datalog it, so I'm not blaming them). I have offerred to help Redraif get it going again (by email), but I haven't heard anything. I'd love to see what it could really do.
Old Oct 27, 2010 | 11:00 AM
  #53
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
any more
Old Oct 27, 2010 | 08:23 PM
  #54
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
both my numbers are on two diffrent motors and the numbers are both NA...there was no boost on the 3.4 as the clutch slipped
Old Oct 27, 2010 | 11:02 PM
  #55
Car: 92 camaro rs
Engine: 3.4v6 sc
o ok ill fix it and who makes the turbo kits any more i know it was dves 12
Old Oct 27, 2010 | 11:46 PM
  #56
project89's Avatar
thats me
Old Oct 27, 2010 | 11:51 PM
  #57
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Mines so bad it got me a ride in the back of a cop car!!
Old Oct 28, 2010 | 04:34 PM
  #58
project89's Avatar
btw i found the roms those numbers were put down at
268 rwhp @ 3904 rpms / 72.6mph
368 rwftlbs @3826 rpms / 71.2 mph
Old Oct 29, 2010 | 03:41 PM
  #59
project89's Avatar
hey u have pilsbury listed under the hybrid section his numbers are not hybrids
Old Nov 5, 2010 | 09:03 AM
  #60
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Are you wanting any V6? Or just the 3.1/2.8/3.4 stuff?
Signature is at the bottom.
~Scott
Old Nov 5, 2010 | 11:46 AM
  #61
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
^ His belongs on the list. We need cars that are deserving of the title. Sub-300hp doesn't cut it. I saw your car in hotrod magazine, pretty cool man.
Old Nov 8, 2010 | 05:09 AM
  #62
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
The event was Sept 09... I drove it the rest of the fall and this spring... I drove up to Milan For a Syclone/Typhoon event and had a exhaust Seat come loose on the #1 Exhaust valve.. I "Carefully" drove back 3.5hrs to home on 5cyl. The heads were used and beat up castings when I bought them.. Champion said they'd last 1 season tops.
I go 3yrs out of them.
I purchased new castings from Champion and sent down all my old parts.. They found that 4 valves were bent.. Not sure how long that had been going on.
It runs stronger now with the new heads and non bent valves.
Not had a chance to go back to the track since.. Might make that 9 second pass on pump gas!
A couple pic's and article.
~SCott
Old Nov 8, 2010 | 06:45 AM
  #63
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
^^^Damn...Your car is ridiculously sexy.
Old Nov 12, 2010 | 08:34 AM
  #64
overide's Avatar
any more
Finally found redraif's graph. Sheesh...I knew I remembered seeing some crazy tq numbers... I was considering the Truleo/3.4 for my Fiero and these results always stuck out in my mind... This was the only car I can remember that had "untuned" before and after results w only changing the intake... 35ish ft/lb jump. Seems the hp moved up decent at each rpm point until you reach the higher rpms. No peak increase and no high RPM gain told me I was NOT gonna spend 600.00 for pitiful top end power... Esp when folks were doing the dohc swaps... and the hybrid swaps.... much better results for the $ IMO.
Old Nov 12, 2010 | 11:23 AM
  #65
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I no longer have the car, but I had a decent 3.4. I had posted some desktop dyno numbers. I think it was around the 180hp mark? The gutted v6 seemed faster then the v8 I have now thats fully loaded.
Old Nov 13, 2010 | 07:23 PM
  #66
project89's Avatar
481 hp @ 6,200 rpms
438 ftlbs @ 5,300 rpms
iron headed 3.0
Old Mar 31, 2012 | 04:10 PM
  #67
Car: 92 camaro rs
Engine: 3.4v6 sc
bump
Old May 8, 2012 | 08:43 AM
  #68
Car: 92 camaro rs
Engine: 3.4v6 sc
bump can i get a sticky ???
Old Nov 30, 2012 | 07:03 PM
  #69
Car: 92 camaro rs
Engine: 3.4v6 sc
go up
Old Aug 2, 2015 | 07:44 AM
  #70
Car: 92 camaro rs
Engine: 3.4v6 sc
back from the died ...do i need to update?
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
