sigh :( engine wont start again...
Old Oct 8, 2010 | 09:25 AM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Long story short i'm in the process of just getting the engine (2.8 v6, 87 firebird) on my project car running again. It was at a point where it would fire up with no problems. One day it ran out of gas while i was working on it so i figured, time to replace the fuel filter anyways. That turned into a nightmare, fuel line broke during that process.
I have now replaced the part of broken line and fuel filter.
Replaced the plugs and wire set.
Replaced the maf sensor.
and replaced the damaged air intake with an aftermarket from autozone.
After all of that now it will not start....
I don't know why and i need some ideas/ solutions.
I know i need to check the fuel and spark and see if that's the problem since both were worked on but i'm not sure how, i know there are easy ways of doing it. Thanks in advance everyone.
Old Oct 8, 2010 | 12:59 PM
02v8ta's Avatar
Car: 1984 Camaro
Engine: Crate 350
Transmission: auto
Re: sigh :( engine wont start again...
hmmmm it might actually be the fuel line after going back and looking at something. Also though how do i test the fuel pump to see if it is working?
Old Oct 8, 2010 | 06:53 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Need a lot more info than that to help, ie. is it even cranking? Fuel pump is easy to check, when you turn the ignition on you should hear the pump priming the fuel system.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
