More camshaft.
Old Oct 11, 2010 | 11:34 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
More camshaft.
I found a custom compcams grind cam@
  • Duration (Intake/Exhaust): 226°/236° @ .050"
  • Valve Lift (w/1.5 Rocker): .463"/.474"
  • Lobe Sep. Angle: 112°
Im running and edelbrock 3790 cam now( http://www.summitracing.com/parts/ED...5&autoview=sku ). Would the custom be too much for a untuned ecm? I'm running a 3.4 with 3.4l injectors, 1.6 rockers and a AFPR. I want more torque and midrange power.
Old Oct 11, 2010 | 11:42 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: More camshaft.
My motor idles like crap below 800rpm and that one has more duration than I'm running. But mine's on a 115 lsa so that one will be alot more manageable. 1.5 rockers would probably give you better low to mid torq.
Old Oct 12, 2010 | 08:02 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: More camshaft.
Would my stock ECM work okay with it?
Old Oct 12, 2010 | 02:41 PM
bl85c's Avatar
Car: '85 maro
Re: More camshaft.
Most likely.
Old Oct 28, 2010 | 06:15 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: More camshaft.
With a cam of these specs:
Intake Duration at 050 inch Lift 204
Exhaust Duration at 050 inch Lift 214
Duration at 050 inch Lift 204 int./214 exh.
Advertised Intake Duration 278
Advertised Exhaust Duration288
Advertised Duration 278 int./288 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.443 in.
Valve Lift with Factory Rocker Arm Ratio 0.420 int./0.443 exh.
Lobe Separation (degrees) 112
http://www.summitracing.com/parts/MEL-CL-MTC-5/
and 1.6 ratio rockers, will the valves kiss stock pistons?
Old Oct 28, 2010 | 10:52 PM
bl85c's Avatar
Car: '85 maro
Re: More camshaft.
I need specifics on what you're building, but I really doubt it.
Old Oct 29, 2010 | 04:44 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: More camshaft.
I'm just looking for more n/a non-hybrid hp. I've come to the realization i will be losing low end torque so I'm just looking for a larger cam then the one I have. I also already have 1.6 ratio rockers.
Old Oct 29, 2010 | 09:47 PM
project89's Avatar
Re: More camshaft.
the closer u can get .500 or above lift the better the iron head flow jumps up considerably after 400 lift. while its mid lift numbers that m,atter the most going to a cam with .515 lift will give u a decent gain over a similar cam with only .430 lift
Old Oct 30, 2010 | 10:53 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Re: More camshaft.
Do you have any high lift cams in mind?
88Camaro350
Jul 18, 2003 05:25 AM
88Camaro350
Jun 30, 2003 10:45 PM
82-T/A [Work]
Jun 10, 2003 05:07 PM
CamaroX84
Sep 9, 2002 09:32 PM
Arntzman
Nov 18, 2001 06:29 PM
